How Much Boost? From 346 -> 370
What I'm trying to figure out is how you guys decide how much you can run on pump gas. Do you make an educated guess? Or do you keep bumping it up until you hear knock, then back it off a bit? Reason I say 'hear' is because my knock sensors or PCM has decided that they won't work. I've replaced the harness and both sensors, no dice.
When I cracked a ringland I was running 12psi, 91 octane, stock motor, + alky injection ( a fair bit too! ). The alky pump seized and boom!
Now I've got a 370ci iron block, fully forged internals, 8.7:1 CR. I'm wondering how much boost to run.
I think my tuner is scared to push it on 91, I just want to get it as high as possible then back it off a bit from there. He's thinking only 10psi, but dammit I built this engine to handle it didn't I??
Let's hear how you guys figure out the max to run, regardless of type of gas.
- Dug
I know you know this but sometimes we forget that just because we ran XX amount of boost on 1 motor doesn't mean we can run the same amount on the new more efficient motor right?
Assume that a stock tune and CR will run on 91. You know the stock mass air flow. You can figure out cylinder pressure. Thats probably close to the most pressure you can have with stock timing. Change the values for your 8.7 CR and find out what the mass flow would be for your new set-up assuming the same pressure. Find out the amount of boost you need for that mass flow and you got it. Not exactly simple.
In the end, there's a lot of dynamic things going on, and you'll have to find it experimentally, but I bet this would get you close. If you have the smaller turbos, you might not get there.
- Dug
I think most start off with small amounts of boost and a medium level of timing and start ramping up till they notice any detonation. Lots of ways to go about it really but since I'm not a tuner I wont advise. I don't wanna give bad advice.
364 cu iron block
i run 12 psi on 93 octane. i can run the same boost no problem with 91 octane....BUT then again...im wayyy up here in the sky....so we can run a little more boost with less octane
- Dug
Watching the scanner and looking at the dyno graphs tell a lot. I am guessing 10-12 psi will be the most on 91 oct with a decent timing map. Our 91 oct gas is ****, and it's quality varies quite a bit from tank to tank. I am not going to let you blow it up, yet.
Bring some 110 with ya so we can really turn it up.
I know, you don't want to blow it up . . neither do I! And I can understand your hesitation. I just see people throwing out #'s, when REALLY that's just a guideline, you have to see what it does on the dyno.
- Dug
If you can make, let's say 600rwhp @ 10 psi and 26 degrees timing and you also find that you can make 600wrhp @ 12psi and 23 degrees of timing then the obvious choice would be to keep it at 10 psi with 26 degrees of timing so that you don't have to up the boost. Or try to find the median of 11 psi with 24 degrees of timing. I'm sure you get what I'm saying. Any time you can find power without upping the boost is always a plus.
- Dug
I have used Torco, the stuff did work good but sure discolored the plugs!
- Dug
