LS1TECH Project "HOSS" - which power adder?
Old Mar 19, 2005 | 01:37 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Talking LS1TECH Project "HOSS" - which power adder?
I recently purchased a low mileage 1999 Hugger Orange SS for a daily driver. photos here I'm planning on doing a forced induction setup on the project, but haven't decided on which route I'll take. Here are my goals:
500-550 rwhp on pump gas
no drivability issues
no reliability issues
must retain A/C and power accessories
quiet operation, nearly stock exhaust sound (I hate loud exhausts)
I was thinking about putting on a set of stock 6.0L heads, and I also have a 230/227 114 cam sitting on the shelf. The car is a 6-speed, and I will be adding a 12-bolt rearend to the car to handle the power.
Whatever setup I go with, I'll be doing a full write-up on the installation, and taking tons of photos. The car is sure to get a ton of coverage, as usual.
So, what do you guys want to see?
Tony
Old Mar 19, 2005 | 02:02 AM
LSs1Power's Avatar
That cam is begging for a Turbo, but you can always get a SDEC 8 rib D-1SC and with a mild cam and call it a day. Good luck.
Old Mar 19, 2005 | 03:34 AM
Wicked_Hugger99's Avatar
me say turbo BTW were did you find the color breakdown on hugger SS's? Been lookin for that forever
Old Mar 19, 2005 | 03:50 AM
DONAIMIAN's Avatar
Ive been thinking about this too for drivability reasons maily, and in the long run it seems cheaper to go turbo. Id be able to make power without the need for a huge *** cam. And for the quiet operation, that isnt a must for me, i just want the turbo so damn big that it dosent spool up till the other side of 3k, lol. Freeway runs would be a whole lot more fun
Old Mar 19, 2005 | 04:01 AM
CAT3's Avatar
Restricted User
I vote for one of the Turbo kits available from a sponsor, more specifically Phamspeed, STS or PTK. I think going with a Phamspeed would be awesome, not only help them out by providing coverage, but ccomplish your goals as well. They definately been working for our community. Just my IMHO.
Charlie
Old Mar 19, 2005 | 06:22 AM
BlwnTA's Avatar
7 Second Club
One for the SC guys here. See my sig....the reason every has problem with SC's is either pushing them too hard (lot's or RPMs on the base kit coupled with the fact that the shitty procharger belt set-up can't handle much for very long)!
Now that SDCE has solved the belt problem...here's my recommendation.
Procharger Kit for that car with an F1 SC. You will not have to spin it as hard (larger pulley) to acheive 10PSI which will put you right in the middle of your desired goal at a minimum.
SDCE Spring Tensioned 8-Rib set-up.....as others will tell you....it's does not slip or break!
Other Pro's...easy to install, no heat issues, easily retain AC. Probably do it for $5k and one long weekend + fuel system upgrade, but you will have to do that anyways.
Good Luck!
Old Mar 19, 2005 | 06:25 AM
Hardtop's Avatar
Turbo would be cool. I would get a 9" over the 12 bolt though.
Bruce
Old Mar 19, 2005 | 07:01 AM
NA$TY-TA's Avatar
hmmmmm thats a hard one Tony. You want to leave the motor alone right? Or bottom end that is.... Id say if you did decide to go turbo give SDCE a call for sure and if you decide to go turbo id like to see you try Phamspeeds kit. Now that a few people have it we will see results soon for HP and track times. I know Jer (FRCEFED) will have his up and running a few days after he recieves all his parts and and will be working on the tune non stop till he gets it.... track times will be soon.
I cant tell you what i think of a turbo setup because my new setup isnt done yet. I know i had ALOT of problems in the beginning with the SC kit.... You know that Tony you were there....... So think about that one....
Thats my .02
Kyle
Old Mar 19, 2005 | 07:05 AM
onfire's Avatar
Coal Mining Director
Twin Turbos................power and cool....and not many around.
Old Mar 19, 2005 | 07:17 AM
Uthinkso's Avatar
408 screw stock sounding......just my thoughts.
Old Mar 19, 2005 | 08:07 AM
White_Hawk's Avatar
I think you should put together a P1-SC setup and show everyone that you don't need a D1 for a sick street setup.
-Geoff
Old Mar 19, 2005 | 08:20 AM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
A big single turbo would be cool to add to your fleet.
Old Mar 19, 2005 | 08:30 AM
Nine Ball's Avatar
LS1Tech Co-Founder
I don't want to touch the shortblock for now. I'd be happy with anything over 500 rwhp and daily-drivable. Yes, those turbos are appealing to me, since I already have had a 525 rwhp NA LS1, and now have a supercharged LS6 in the '69. No turbos yet
Tony
Old Mar 19, 2005 | 08:35 AM
Got Me SOM's Avatar
Twin Turbo! Or Big Single Turbo like a T-88, Big Front Mount, AFR heads and cam package. Should make over 500 with ease... I think you should try get 130 mph trap speed with a stock bottom end.
Can I Have The Car When You're Done?
Old Mar 19, 2005 | 08:51 AM
Nine Ball's Avatar
LS1Tech Co-Founder
read carefully: I don't want a 408 right now. I also don't think it is necessary to run twins for only 500 rwhp, right? Who makes a twin kit that keeps the A/C?
Old Mar 19, 2005 | 08:56 AM
Got Me SOM's Avatar
Find an old Incon kit. I edited my post above yours and took out the 408 comments and threw some new ones in there.
Old Mar 19, 2005 | 11:01 AM
69firebird's Avatar
there are 2 CAS kits for sale right now, they keep AC.
The phamspeed kit, is really nice but wont allow you to keep ac as I remember, o rwill it????
Old Mar 19, 2005 | 11:20 AM
kp's Avatar
kp
Heads/cam/nitrous and your done
I wouldnt do anything where you had to cut apart the bumper cover for an intercooler. I would do a P1SC or D1SC with the stock intercoolers and a 6 rib SDCE spring tensioner, decent headers and call it a day - easy 500rwhp on pump gas with a M6. Racetronix in-tank, 42lb injectors, gauges and a good tune and thats about it. Plus you really dont have to chop the car up to do it, only downside is noise and running hot with the a/c on, some car do and some dont. Plus its easy to work on, self contained oiling and if something screws up on the road just stick an air filter on the MAF, cut the belt and drive it on home..
With the M6 in my old car and a P1SC with MAC headers, through MAC cats and a stock dual/dual I made 486rwhp with like 7psi. Stock cam, stock heads, LS1 intake etc and the car drove like stock and still got stock gas mileage - hard to beat that. Only downside was belt slip and the ATI idler pulley wearing down, all that would be fixed with the SDCE kit.
Old Mar 19, 2005 | 11:42 AM
WS-Sick's Avatar
Well it sounds like Phamspeed may be for you. Their kit will meet your power goals easily and there will be plenty left in the kit whenever you decide to go forged (if you do). There's a vid of Amargeddon's car that got posted in this section. He's not even tuned yet and that thing is running really strong.
https://ls1tech.com/forums/forced-induction/292068-armageddon-s-car-phamspeed-video.html
Edit: I see you already posted in that thread...
Old Mar 19, 2005 | 11:55 AM
sb427f-car's Avatar
SSU'S Vice Mod
Hey Tony, how hard was the install on the 69? I was on my way into work this AM and drive past a first Gen for sale. I'm stopping to look @ it on the way home. I hate that life is full of choices!!!!
