Many questions about my Radiator
Where is your radiator?
Will it work that low?
Where is your water pump?
How will you attach the -12 hose to the motor mount?
etc.. etc..
So here you go!
This is how the radiator is mounted. It is tucked up under the front facia.
Clean and hidden out of the way.
I do not have a standard water pump. I have a Meziere remote water pump and here is how I will attach the -12 lines from the pump under the frame to the motor mount.
I can mount the radiator that low because I got a Meziere expansion tank. As you can see, the tank has the filler cap on it and it will be located higher than the radiator. It also comes with -4 bungs for the head steam vents.
None of this stuff is custom! It is all on the shelf at Meziere.
Thanks and Good Luck!
Tom
etc.. etc..
So here you go!
Tom
also you plan on running wter in the head or block first
The block adapters are WP89U. You will will also need 4 WP12012B -12 fittings. I have 2 -12 fittings welded to the top of the radiator and a -8 on the bottom along with the standard nipple. The pump will fill the block first and return from the top to the 2 -12's in the top of the radiator.
Tom
If you're interested let me know when you're ready to get the BS3. I'll get you a VERY good price.
Part Number = 2-58185-XC
Core = 2 row 1.25"
Style = Scirocco
Dimensions = 22 x 13 Double pass - w/shroud & fan
Tom
