Ls6 Cam Not Enough?
Old Mar 23, 2005 | 03:45 PM
SELLSZ06's Avatar
Default Ls6 Cam Not Enough?
Iam In The Process Of Putting Phamspeed Turbo With Patriot Heads On My Car, However The Shop Doing My Heads Is Recommending A 02- Newer Ls6 Cam, I Think Its Way To Mild. I've Talked To Different Shops And I Get Different Answers Everytime. What Cam Are The Turboguys Here Running. I Wanted It To Be Reliable And And Be Able To Idle Well. LOOKING FOR AT LEAST 550RWHP WITH STOCK BOTTOM
Old Mar 23, 2005 | 03:48 PM
Hagarr's Avatar
Not that I am an experienced turbo guy but I was thinking of the LS6 cam my self along with upgrade springs etc along with my mild turbo setup I have planned.
I too would like to know if it is a good choice.
Brian
Old Mar 23, 2005 | 03:52 PM
Wnts2Go10O's Avatar
custom turbo cam might be best for u guys. ull get your moneys worth
Old Mar 23, 2005 | 03:54 PM
Wnts2Go10O's Avatar
PS: 550 rwhp ona stock bottom, if im not mistake, is pushin it. make sure you have one hella good tune done
Old Mar 23, 2005 | 03:56 PM
SELLSZ06's Avatar
IAM SURE THAT IS PUSHING IT BUT I DO PLAN ON FORGED BOTTOM-END WHEN FUNDS ALLOW IT
Old Mar 23, 2005 | 04:11 PM
HellRaiser's Avatar
550 is easy from everything I read. It's all in the fuel system and tune.
Old Mar 23, 2005 | 05:04 PM
MIGHTYMOUSE's Avatar
i made 787rwhp with a stock 1998 camshaft and ran the time in my sig.
if you want noise, get a cam, if you want power, spend it elsewhere.. especially for only 550 horse.
Old Mar 23, 2005 | 06:26 PM
Hagarr's Avatar
10-4.
Thank you sir.
B
Old Mar 23, 2005 | 10:12 PM
mdhmi's Avatar
If you want something similar to a Z06 cam but slightly more aggressive have a look at the LPE GT2-3 cam.
Mark
Old Mar 23, 2005 | 10:59 PM
Lawnboy's Avatar
Restricted User
I had Cammotion custome grind a 222/216 560-574 115 + 4 =111LSA reverse split turbo camshaft.
I will be installing a STS T67 rear turbo- intercooled, running 12-14 PSI
Diamond -8.6 boost pistons, 241 LS1 Absolute Speed hand ported heads, flowing 300 CFM at .600
I would go with a cam like this, dont need a big cam with a turbo. But get a reverse split turbo came, to prevent reversion.
Old Mar 23, 2005 | 11:05 PM
Lawnboy's Avatar
Restricted User
Phamspeed turbo system, whats there Web sight???
Old Mar 24, 2005 | 04:59 AM
HellRaiser's Avatar
http://phamspeed.com/
Old Mar 24, 2005 | 08:29 AM
Got Me SOM's Avatar
The weakest link in your bottom end is your ringlands. It doesn't matter how good of a tune you have, they have a threshold limit of so much. 550 on stock bottom will not last too long.
Keep your tune conservative and just keep it at 7 lbs, that will ensure your motor stays alive till your new bottom end goes in. You should be able to make 450-500 easy with that.
I'd wait on a cam as well. Of course its up to you.
Old Mar 24, 2005 | 11:22 AM
SELLSZ06's Avatar
Default Cam And Injectors
I HAVE 571/571 224/224 @112, AND THATS NOT GOING TO WORK ON MY NEW TURBO AND HEADS, SO I NEED TO GET A CAM ANY WAY. IWANTS THIS TO BE VERY RELIABE BUT I DO WANT TO MAKE AT LEAST 600RWHP AFTER THE FORGED BOTTOM IS PUT IN IN A FEW MONTHS, AND TURN THE BOOST UP AFTER. BUT FOR NOW IAM LOOKING@ 6-7LBS. WHAT DO YOU THINK? ARE 42LBS ENOGH OR SHOULD I GO WITH 60S. THANKS FOR ANY HELP U CAN GIVE ME
Old Mar 24, 2005 | 11:25 AM
SELLSZ06's Avatar
So Is There A Shop That I Can Call And Get Some Reliable Answers? I've Even Called Comp Twice And Got Two Different Answers. WHAT CAM IS BEST?
Old Mar 24, 2005 | 12:14 PM
i like the 60# injectors better than the 42's.
i allready said the stock cam is best for that kinda power
Old Mar 24, 2005 | 12:21 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
We can help you with cam selection and we can order custom units as well.
Jose
