have a problem under boost?
Old Apr 6, 2005 | 08:25 PM
84camaroturbo's Avatar
Default have a problem under boost?
just put my new motor in and when i get it to about 5psi it makes a big pop throught the intake then i just let out off it. before i was running 13 psi and no problem the only difference is i have aluminium heads and custom turbo headers.
Old Apr 6, 2005 | 08:32 PM
sb427f-car's Avatar
SSU'S Vice Mod
Need more info. @ what RPM, how much timing are you pulling...(not that I'll be able to directly answer the question, but I know what needs to be asked for the guys that do).
Old Apr 6, 2005 | 08:45 PM
it is about 4500rpm the timing is about 25 btc. the car is runiing rich the meter says it is rich as hell. i never had a problem like this before and just cant figure it out. they say the heads will help with detonation. if pull hard as hell until the pop then i just quit. and the car runs the same after the pop as before.
Old Apr 6, 2005 | 09:14 PM
sb427f-car's Avatar
SSU'S Vice Mod
What turbo are you trying to run...almost sounds like you're getting a compressor surge.
Old Apr 7, 2005 | 08:45 PM
i have two to4b one other mod is i put a intercooler on it. i was talking to a guy at work and he thinks that i might have a cross fire in it some were. either the cap rtr or wires are cross firing. i have order wires but havent made it yet.
Old Apr 9, 2005 | 04:45 PM
i figured it out i had a bad cap and rtr it was crossfireing in the cap but thans.
