Is it possible to upgrade from a p-1 to a d-1?
Old Apr 9, 2005 | 11:27 AM
CMKworm's Avatar
Exclamation Is it possible to upgrade from a p-1 to a d-1?
If so what all would I need? How much?
Old Apr 9, 2005 | 12:09 PM
TTPMatt's Avatar
Yes, ATI will rebuild a P-1 to D-1. I believe they charge ~$300 ?
- Matt
Old Apr 9, 2005 | 12:27 PM
Wet 1's Avatar
I had heard it was closer to $1000, please let us know what you find out.
Old Apr 9, 2005 | 01:11 PM
TTPMatt's Avatar
This is on spec. I was actually told by a customer. We rarely deal with ATI units.
Old Apr 9, 2005 | 03:51 PM
ATVracr's Avatar
I was told by ATI $1000 P1->D1 when I was inquiring about a prototype F1-D headunit to put on a blown 6.0 1500 Sierra were workign on
Old Apr 9, 2005 | 04:05 PM
mdhmi's Avatar
Upgrading from a P1 to a D1 is around a grand, however, when you purchase a kit new the D1 is only a few hundred more than the P1.
Mark
Old Apr 9, 2005 | 04:50 PM
Grasshopper's Avatar
By the time you pay for shipping and everything it's more like $1,200. That's going from a good P1SC to a D1SC. If there's anything wrong with your P1SC, it'll cost you more depending on what's wrong with it.
BTW a "D1" is an oil fed blower with a 4.44 gear ratio VS. a "D1SC" which is a self-contained blower with a 4.0 gear ratio.
Old Apr 9, 2005 | 05:38 PM
CMKworm's Avatar
Everyone is telling me that I should upgrade because of my other mods, plus I can't make boost w/ the cam I have now!
http://www.cardomain.com/id/cmkworm
Old Apr 9, 2005 | 07:15 PM
Wet 1's Avatar
I'm making over 600 rwhp with a P1SC on a basically stock Z06. It sounds to me like your problem might be the 112 LSA of your cam... not your P1SC. The P1SC is capable of more than your 42# injectors.
Old Apr 9, 2005 | 07:23 PM
frcefed98's Avatar
But your 11.1-1 compression ratio helps with that as well as better flowing heads, as well as a better s/c pulley set up which is dog crap on the LS1 F-body kit. The D1-SC has a hard time making a lot of power on an F-body than it does on a C5...same goes for the P1. Comparing a Z with P1 to a LS1 f-body with a P1 is apples and oranges.
So the question has been answered, yes the P1 can be upgraded to a D1 and it'll run you upwards of a grand.
J
Old Apr 9, 2005 | 07:50 PM
CMKworm's Avatar
I'll try the cam first!
