my turbo cam experience
346 forged with incon turbo kit.
first cam was 220/224 114 i forget lift but this was made for a s/c
best slip was 1.6ish 60'
6.6ish 1/8 at 105
10.45@ 130 i forget the specifics.
next cam was designed by cammotion with all my specs...including rear and weight. It was 231/226 115. best slip was 1.6ish 60'
6.7ish 1/8 @ 107
10.49@132...car lost .10 in the 1/8 but mph better
current cam is an old grind 215/215 114 best slip is 10.34 @121 (fuel pump wire grounded out around 1000' mark) 1.59 60' ....6.62 1/8 @ 107
The smaller cam has better driveability...idle...and more along the lines of what I was looking for in a 10sec daily driver. My incon kit is maxed and the reverse split should have really kicked *** but it didnt. My final opinion is cam is not THAT important and should be dictated by 60'...gear and weight requirements. After the 1/8 mile it doesnt seem to matter what cam is in the car...the turbo(s) get it done. This is my opinion on my results and not debating reverse/standard/no split advantages/disadvantages. Just thought I'd throw it out there for the little people like me who spend HOURS researching different cams.
i think my next cam will be a little smaller, i dont know i might try throughing in the stocker to see if it works better.
my car did 787rwhp 841rwtq on a stock 98 cam, stock unported ls6 intake stock ported tb
same boost level with a pretty big cam and 20ci more displacment it made another 30 horse...coulda got that 30 horse with just 1 more psi of boost... but it wouldnt be in the same spot on the curve.. and thats what i needed the most.. i'm trying to get some decent mph outa this thing.
p.s. i have no idea where i heard the above info but i did from somewhere.. dont quote me.
Smokinhawk: it did go 136mph earlier that night when playing around some.
202/210 intake/exhaust degrees duration
.496/.496 inches lift
116 LSA
Fbody LS1 cam '01-02:
198/197 intake/exhaust degrees duration
.466/.478 inches lift
115 LSA
Ybody LS1 cam '97-01:
198/208 intake/exhaust degrees duration
.500/.500 inches lift
115.5 LSA
Old LS6 cam:
207/217 intake/exhaust degrees duration
.525/.525 inches lift
116 LSA
New LS6 cam:
204/218 intake/exhaust degrees duration
.551/.547 inches lift
117 LSA
On the engine dyno at W2W the car made 1108/11xx by 5500 on 20psi but was falling off a bit after that. Interesting thing is that from 4600 or 4700 (been a while since I looked at the numbers) on up it made over 1000 ft/lbs. Kurt said that it is time for better heads or a bigger cam!
I will try and find it and scan it in so that you guys can take a look.
I believe that it was a 94mm turbo that they used, Kurt can correct me if I am wrong.
Check out the link.http://www.boostdoctor.com/clips/564.wmv
Please right click and save as.
