p1sc-1 cam suggestions
Old Apr 10, 2005 | 07:43 PM
potholesrbad's Avatar
Default p1sc-1 cam suggestions
looking at doing some mods
procharger p1sc-1 with fuel system
slp longtubes
random tech cat
borla catback
cnc ls6 heads
what cam should i plan on going with and are these mods safe on stock bottom end what kind of rwhp #s would i be looking at through an a4 with a 3200 stall with good traction what can i expect to run at the track
Old Apr 10, 2005 | 11:13 PM
mdhmi's Avatar
02+ Z06 cam or LPE GT2-3, at least if you are looking for great driveability like me.
Cheers,
Mark
Old Apr 10, 2005 | 11:18 PM
thats exactly what im looking for that and 11s on drag radials
Old Apr 11, 2005 | 08:13 AM
snkchrmr's Avatar
I went with the TR blower cam. With LT's and P1 it made 470rwhp after swaping to the cam it made 549rwhp. It idles good and drives good.
Old Apr 11, 2005 | 08:52 AM
Got Me SOM's Avatar
you won't need a cam to do 11's on drag radials. 11's will be a breeze.
Old Apr 11, 2005 | 08:54 AM
Got Me SOM's Avatar
I just noticed you have ls6 heads, I would switch back to stock heads if you have, they're gonna raise your compression.
Old Apr 11, 2005 | 01:08 PM
stock heads, cam, p1sc, fuel system, full exhaust this sounds good and less expensive also anything else i should add???
Old Apr 12, 2005 | 01:46 PM
BlOWNSS's Avatar
Chrome-Moly Pushrods would not hurt
Old Apr 12, 2005 | 02:04 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd go with ported 6.0 heads (70cc) vs ported LS6 heads (62cc).
What are the specs of the TR blower cam?
Old Apr 12, 2005 | 02:21 PM
NA$TY-TA's Avatar
Im with you PSJ......
Go with a set of 6.0L heads to lower your compression a bit... and the cam i always reccomend is the same cam PSJ above likes also.
The 224/230 .580ish/.590ish lift on a 114LSA. The TR cam is a 227/230 i believe... not sure the lift and i think on a 114LSA.
Kyle
Old Apr 12, 2005 | 02:32 PM
snkchrmr's Avatar
The TR is 224/227 562/567 114. It's a medium size cam, it also has aggressive lobs like the XRE comp cams.
Old Apr 12, 2005 | 02:54 PM
LS1Tech Co-Founder
224/227//114 sounds pretty good, it would have a nice healthy bump in duration but still be able to be shifted by 6500.
Old Apr 12, 2005 | 03:05 PM
NA$TY-TA's Avatar
Did you mean XER lobes????
That cam will work.... SC like a reverse split....
Kyle
Old Apr 13, 2005 | 09:35 AM
snkchrmr's Avatar
Kyle
Yeah, (XER). It's suppose to be from 2200 to 6700 rpm range. I didn't turn it more than 6400 but on the graph it's still climbing.
Old Apr 13, 2005 | 02:13 PM
NA$TY-TA's Avatar
Im running a comp XER cam also and i was told it is there most agressive lobe. Mines a lil bigger then the thunder cam....
Kyle
Old Apr 13, 2005 | 02:18 PM
Next Phase's Avatar
MTI G1 blower cam
Old Apr 13, 2005 | 02:24 PM
whats the most you'd want to spin a stock block ls1 rpm wise? i was thinking safely 6500 maybe
Old Apr 13, 2005 | 02:30 PM
Next Phase's Avatar
My H/C is setup for 6600 rpm.... If you are talkin' about w/ boost...it depends on how much boost and hp you are making.... I'm gonna have to back off my rev limiter because I'll be over 600 rwhp if i keep the 6600 limiter....KABOOM
Old Apr 13, 2005 | 02:53 PM
NA$TY-TA's Avatar
Ive seen alot of my friends spin theres to 6800-7K.....
Im only going to spin my built motor to 6600rpm though...... its seems the motors last longer when you shift lower.....
Old Apr 13, 2005 | 03:07 PM
Next Phase's Avatar
Hey bro,
just saw your vidy of your car in the garage......sounds bad ***... definately a lot more of a lope than i have on my vette....
