FI people who are running the GMPP single plane intake....
Old 04-15-2005, 06:54 PM
SPANKY LS1's Avatar
Default FI people who are running the GMPP single plane intake....
FI people who are running the GMPP single plane intake, what are the advantages/disadvantages of running this intake on a FI setup? Better flow? Better distribution? Do you have pics of your setups?
Thanks, Shawn
Old 04-15-2005, 08:52 PM
smokinHawk's Avatar
^haha, funny sig!!
anyways what i heard the single plain flows the best.
might not help down low but when your pulling that much air, especially in the uper rpm range it will sine
Old 04-19-2005, 11:19 AM
NA$TY-TA's Avatar
I am wanting to know more info on this also.
Kyle
Old 04-19-2005, 11:29 AM
kp
kp's Avatar
The GMPP will flow a lot of air and thats what you want with a forced induction car The GMPP worked just fine on my old n/a car - no complaints whatsoever except some funky distribution that was handled by trimming the individual injectors with the DFI but harlan hasnt hasnt had any distribution problems with his under boost as far as I know. If I was doing a high horsepower FI car I would use one without a doubt.
Old 04-19-2005, 12:22 PM
SSU'S Vice Mod
sb427f-car's Avatar
Basically it's the cheap alternative to using a sheetmetal "box" plenum design, much like a manifold you'd see on a pro stock or GM DRCE block. The overall basic appearance of the GMPP single plane looks like a NASCAR "spyder" SB2.2 intake manifold, and if that can keep up with a 4 bbl @ 10k RPM, I'm sure these will flow pretty darn good with some #s on top of them and not as much RPM.
Old 04-19-2005, 01:05 PM
Guido's Avatar
That argument is basically center feed intakes vs. front fed intakes and the distance that the air has to travel from the TB to the valve via the intake plenum/runner combination.
Center feed intakes are obviously going to distribute better than an intake with the TB on teh front
Old 04-19-2005, 03:23 PM
NA$TY-TA's Avatar
Anyone have a direct link to one and know how much they are???
Kyle
Old 04-19-2005, 03:43 PM
69firebird's Avatar
go to scoggin dicky, there 339.99
Old 04-19-2005, 04:00 PM
WS-Sick's Avatar
Are there any necessary modifications that need to be done to make them fit on...a turbo setup for instance?
Old 04-19-2005, 04:01 PM
chronic masturbator
dynedta's Avatar
the scoggin manifold is not drilled for injectors though there was a guy on here doing a single plane kit with elbow, fuelrails, and predrilled manifold I think the name was aaronl
Old 04-19-2005, 04:11 PM
69firebird's Avatar
the GMPP has the BUNG aera built in, it just needs to be drilled out, if you have LS1ASpeed rails they will work
then you just need an elbow.
ed
Old 04-19-2005, 04:38 PM
Moderator
LIL SS's Avatar
Here is another $1000 I did not want to spend this year..
$339 for the intake and $650 for a serious TB.
Old 04-19-2005, 04:55 PM
NA$TY-TA's Avatar
Hereya go.....
https://ls1tech.com/forums/lsx-parts-sale/282822-custom-ls1-efi-intake-manifold-w-elbow-fuel-rails.html
I was looking for it today also and found it.
Not a bad price....
Intake & fuel rails only: $475
Elbow only : $175
and a Ford 105mm TB for $300..... Thats cheap....
Kyle
Old 04-19-2005, 04:59 PM
chronic masturbator
dynedta's Avatar
thats the one
Old 04-19-2005, 05:18 PM
69firebird's Avatar
not a bad deal, if you already have a aftermarket TB and fuel rails.
I talked to them, they said that the LS1Speed rails I had would work, and I currently have a BBK TB, so I could upgrade in the future to a 90 or larger with the same elbow from them.
Seems like a great deal.
I wish the spending on this car would stop. LOL everytime I come on here I find one more thing to spend cash on
ed
Old 04-19-2005, 06:28 PM
NA$TY-TA's Avatar
ed
ha ha
Same here it wont end for me for a while......
I already have the rails also so thats a relief........ i wonder how much for the intake with it drilled for injectors and fittings in the rear for the other stuff like a normal intake..... and the TB and im done...... ill try and find the TB link....
Kyle
Old 04-19-2005, 07:06 PM
SSU'S Vice Mod
sb427f-car's Avatar
Nah, definately not me
I'd think the only really pain in the *** part about it would be drilling the manifold. Other than that it's just cutting the right thickness sheetmetal to size, drilling a few holes in a flange, and welding it up. Granted, it might not be worth the hassle if someone else does it though.
Old 04-19-2005, 08:51 PM
69firebird's Avatar
on that elbow you could have some vacuum ports comming right off of it. thats what harlan said he had done, that his elbow had ports comming off the base of it.
Old 04-19-2005, 09:29 PM
SSU'S Vice Mod
sb427f-car's Avatar
For boost gauge, BOV and wastegates 69? Makes sense.
Old 04-19-2005, 09:34 PM
69firebird's Avatar
BOV, Wategate, Fuel pressure regulator, Brakes, MAP sensor, there are alot of things that get plugged into that manifold that you dont really think about.
Luckily we dont have anywhere near as many as ford motors, there are damn near a million it seems on ford products.
Quick Reply: FI people who are running the GMPP single plane intake....
