Finished twins pics
Old Apr 18, 2005 | 07:13 PM
Tiago's Avatar
thats bad ***!
Old Apr 18, 2005 | 07:17 PM
Raptor99's Avatar
Looks bad-***.
How much did everything cost you? Would you ever do a similar setup for anyone else?
Old Apr 18, 2005 | 07:20 PM
sb427f-car's Avatar
SSU'S Vice Mod
Originally Posted by Raptor99
Looks bad-***.
You beat me to the punch. I have a feeling that's what I'm going to do. How much stuff did you have to relocate besides the alt.
Old Apr 18, 2005 | 07:31 PM
99t66ls1's Avatar
Im around 6000 in parts, since i did all the labor that was about the total, we would do another one but it would be very expensive, it is really labor intensive,
Radiator moved, alt moved, fuse blocks and wiring moves, cruise control, thermostat outlet has to be cut of and reclocked to clear the header, both coolant lines are custom hard piped, front bumper suppport, abs box, ps lines that is about all the relocation i can think of now but im sure there is more.
Old Apr 18, 2005 | 07:32 PM
sb427f-car's Avatar
SSU'S Vice Mod
BTW, where did you route the downpipes?? Stock K-memeber or aftermarket tubular? I think you told us you were using 321 stainless?
Old Apr 18, 2005 | 07:36 PM
sb427f-car's Avatar
SSU'S Vice Mod
Well..I can live without crusie control, hell, I hardly use it anyways, even on a long haul trip. Considering I wouldn't drive it much in the winter, I could run without a T-stat, relocated alt, no biggy, fues box, same thing, wiring, that's a little hair but not bad if you label stuff, abs, either delete it or relocate it, ps could be a bit tricky. Yeah, you've done some work, but it looks killer, congrats, and get us some vids of that nasty *** thing
Where did you relocate most of the stuff to? Passanger compartment? Did you use anything like a painless fuse box, harness, and switch panel combo? Reason I ask is I love the setup and will probably do something like this, but in the distant future (can only plan too much though)
Old Apr 18, 2005 | 07:38 PM
sb427f-car's Avatar
SSU'S Vice Mod
BTW, change your sig, unless you're dislexic or simplely insane. T76 Setup???
Old Apr 18, 2005 | 07:45 PM
99t66ls1's Avatar
Downpipes just go down and dump at the front wheels, its really not that loud ive ran it that way for 2 years and never been hassled, i just relocated all of the stock wiring higher up on the strut tower, all still factory wiring, ps doesnt have to be relocated just the lines (no biggie), stock k member still.
Fine ill change my sig, should i change my user name too.
Old Apr 18, 2005 | 07:54 PM
sb427f-car's Avatar
SSU'S Vice Mod
Oh, lol, sorry, I didn't realise that was your old setup. Could you have routed the down pipes back and out? Or is there no room or would you have had to make more relocations? The only thing that bothers me about having a street car dump the DPs there is if you are stuck idling in traffic for CO. Also to keep the "sleeper" stock look too.
Old Apr 18, 2005 | 08:05 PM
BSRMotorsports's Avatar
What thickness tubing are you using for the manifolds? Also what material?
Brad
Old Apr 18, 2005 | 08:18 PM
99t66ls1's Avatar
No no way you could bring the downpipes back unless you wanted to run them under the k member, its 304 stainless dont remember the thickness offhand we get everything from spdexhaust.com.
Old Apr 18, 2005 | 08:19 PM
  #32
Z06PSI's Avatar
At max boost isn't the MAF about worthless though... My setup is very simliar that I am planning now. A little more track orientated though..... T-62's with 2700lb raceweight.... No creature comforts at all... looking for a High 8 low 9.
Old Apr 18, 2005 | 08:22 PM
  #33
PRAY HRD's Avatar
i'd like to know what hose you used to connect the 105mm t-body to the inlet pipe please? is it a 4.5" to 4" or is the inlet pipe the only reducer, meaning a 4.5" to 4.5" hose? and last, where did you get it and for how much?
thanks,
Dave
  #34
99t66ls1's Avatar
maxes out at about 13 pounds, that will soon be solved though bs3
Old Apr 18, 2005 | 08:25 PM
  #35
hc_performance's Avatar
excellent looking setup!!!! very very nice What heads are you using?
Old Apr 18, 2005 | 08:46 PM
  #36
99t66ls1's Avatar
The pipe is 4 inch and i had it flared to 4.5 inches for about 4 inches and them i just used a 4.5 inch silicone coupler, the heads are completly stock minus valvesprings.
I paid 15 bucks to have the pipe flared here locally at dr gas.
Old Apr 18, 2005 | 08:52 PM
  #37
69firebird's Avatar
do you think that youd gain a good bit of power if you had a nice set of heads?
Old Apr 18, 2005 | 08:54 PM
  #38
99t66ls1's Avatar
Yes i do wanna give me some
Old Apr 18, 2005 | 08:55 PM
  #39
Z06PSI's Avatar
Already looking at that now.. my car is still in the purchase phase and I have alot more than 6K... but I am replacing everything.... brakes,suspension,drivetrain, gutting everthing and a 10 point cage. should be interesting....
Old Apr 18, 2005 | 08:56 PM
  #40
BlwnTA's Avatar
7 Second Club
Very nice....Very Clean install!
