Turbo Blanket - Bad Idea?
Old Apr 27, 2005 | 11:22 AM
Blackbird's Avatar
Default Turbo Blanket - Bad Idea?
Starting to read up on these. First red flag I see is one maker recommends not using it for a daily driver, saying when you park the car the blanket works so well retaining the heat that you start cooking the oil and such and as a result shorten the life of the turbo.
From the website.....
As these Blankets are designed to retain heat within the turbo, it is recommended that the blanket be removed for vehicle "Garaging" as retaining the heat without the water/oil circulation may cause long term reduced life for the turbo (this is particularly relevant when used with non-water cooled plain bearing units.
What do you experts think?
Reason I ask is that there is no doubt with the STS it spools quicker when warmed up. From my testing it's about a 400rpm difference. I can live with it but if there is something easy with no negative effects I can do to make it more consistent I would like to do it.
Old Apr 27, 2005 | 11:57 AM
CHRISPY's Avatar
With an STS kit I wouldnt think you'd have to worry as the temps are so low to start with plus the oil goes a long way in each direction.
I think it's a good idea, give it a shot. Did you wrap your Ypipe and int pipe already?
Old Apr 27, 2005 | 12:01 PM
Blackbird's Avatar
no, haven't done anything. wanted to see how things worked first before mucking with it.
Old Apr 27, 2005 | 12:32 PM
sb427f-car's Avatar
SSU'S Vice Mod
My guess would be that if you have proper oil draining and you let it cycle after hard/spirited use, you should be ok. Obviously what is of most concern is the oil cooking on the thrust surfaces and carbonizing. Though, it was something I was curious about myself, as wraping headers to keep temps down underhood and in the exhaust.
Old Apr 27, 2005 | 01:40 PM
KissMySSo1's Avatar
It's a good idea. Turbo will spool quicker because the blanket is keeping the heat in the exaust side.
Old Apr 27, 2005 | 01:49 PM
smokinHawk's Avatar
your not wraping the center section which holds the bearings, just the exhaust section
should be fine.
Old Apr 27, 2005 | 03:14 PM
Blackbird's Avatar
good point smokin.
I may just give this a try.
Old Apr 27, 2005 | 03:15 PM
CHRISPY's Avatar
I think you should. It'd be interesting to see the results
Old Apr 27, 2005 | 05:37 PM
Avengeance's Avatar
Heath.. if it was me Id wrap everything... retain as much as possible... including a turbo blanket.
Old Apr 27, 2005 | 06:02 PM
Blackbird's Avatar
afraid to wrap the exhaust. wont it rust out?
if not I may go for it.
Old Apr 27, 2005 | 06:39 PM
Avengeance's Avatar
Nahh... people wrap exhaust parts all the time.. headers and such. It wouldnt hurt at all to wrap all of it.
This would be interesting to see if it does make any kind of a dent in lag time.
Old Apr 28, 2005 | 09:21 AM
CHRISPY's Avatar
I'd definitely wrap the Ypipe and intermediate pipe, you wouldnt have to worry at all especially if it is stainless
Old Apr 28, 2005 | 09:44 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Turbo blanket does work good. We use them on ALL our kits.
Turbo Blanket click
Jose
Old Apr 28, 2005 | 11:14 AM
Blackbird's Avatar
guess I will have to save my pennys then.
now how big a difference is there between the $140 blanket vs this?
http://www.jegs.com/cgi-bin/ncommerc...82&prmenbr=361
if this is just as good as the blanket I could then use the $40 saved to buy wrap for the exhaust itself.
Old Apr 28, 2005 | 01:15 PM
KissMySSo1's Avatar
It will perform better and keep your engine compartment temps down.
Old Apr 28, 2005 | 01:19 PM
LS1TECH Sponsor
The blanket uses a flame resistent inner liner and has ceramic beads in it. Very trick, its a hot item right now that we are selling to the Supra crowd. Heck I have 2 that I keep for my SS...hehe
Jose
Old Apr 28, 2005 | 01:34 PM
Blackbird's Avatar
hmmm ok, now the blanket doesn't look to be as much of a one size fits all deal.
yet I don't see anywhere to choose the size of turbo I have. how does this work?
Kiss - could care less about under the hood temps, I am one of those STS losers
Old Apr 28, 2005 | 01:38 PM
LS1TECH Sponsor
The blanket is for T3 or T4 turbos, we carry both versions. But I only advertise the T4 version.
Jose
Old Apr 28, 2005 | 01:40 PM
Blackbird's Avatar
So would either of those fit what I have?
I have what STS calls a GT67
Old Apr 28, 2005 | 01:43 PM
LS1TECH Sponsor
Yeah its a T4...thats the standard in turbocharging.
