Electric Fans for FI
Old May 1, 2005 | 07:51 PM
HellRaiser's Avatar
Default Electric Fans for FI
I need to order fans and wanted to know what you guys were using. I was looking at the Flex-a-Lite Low Profile Cooling Fans Part #240 I think but they cost $209 I was wondering if this is what everyone here was using.
Thanks
Old May 1, 2005 | 07:56 PM
ddnspider's Avatar
im with you on this i think frcefed told me the part number to use but i forgot what it was.DAMNIT!ask him
Old May 1, 2005 | 08:01 PM
HellRaiser's Avatar
Hes the one that told about those fan's. #240 I was just wondering if there was any other option's.
Old May 1, 2005 | 08:41 PM
69firebird's Avatar
has anyone ever though about using hte stock fans as pushers?
I dont have A/C and am going to try to put hte stockers in front and reverse the polarity on them and they will spin the other way
ust a thought, I dont think it would fit if you have the AC condensor in place
ed
Old May 1, 2005 | 08:47 PM
618HAWK's Avatar
Any idea what the specs are on the #240 vs the fan that comes with the ATI kits, is is bigger or dose it flow more ect. I just installed a ATI supplied unit and dont want to have any heating issues, this summer cant go any bigger due to clearance issue with a custom setup.
Thanks
Old May 1, 2005 | 08:51 PM
HellRaiser's Avatar
Dual-Unit fans for V8's to 280HP (250HP with A/C).
12'' fans. Requires 15-1/2''x26-1/4''x4-18'' mounting surface area. Pulls 2500cfm of air using 19.5 amps
Thats right from jegs.
Old May 1, 2005 | 08:59 PM
618HAWK's Avatar
So I take it this setup is a lot larger than the supplied ATI 1 fan setup. or dose it use the same space as the 1 fan???
Old May 1, 2005 | 09:08 PM
RICE ETR's Avatar
Turbo Addict
ed
they will spin the other way if you reverse the polarity.... problem is the fans blades are not designed to do that. I tried it before ordering fans and they move considerably more air as pullers. I just ordered to high speed pusher 12" fans from spal
Old May 1, 2005 | 09:09 PM
frcefed98's Avatar
They work for me??
If you want to try....try to get spal duals as pushers....don't think they make em but...
I live in the desert, drive to the track on city streets which is about 26mi from my house in stop and go and my car stays nice and cold. I do have my fans programmed to come on at 180 but thats so the engine doesn't have a chance to get too hot. Car always runs in the 190 range.
J
Old May 1, 2005 | 09:39 PM
HellRaiser's Avatar
I think he was talking about using the stock fan's.
