Whats your thoughts on a Wiseco -36cc piston, horizontal gas ports, 1/2" head studs?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Talking over a new 410ci T80 turbo set up and then talked to a guy at Wiseco about a -36cc or it might of been a -38cc dish to get 8.7.1 compression with my 64cc LS6 heads. He said theres people making over 1000rwhp with -36cc pistons without problems. Wanted to see if anyone here was making some big power like I am looking for 850+rwhp with a -36cc piston?
horizontal gas ports...dont know much about them but was told for each piston with them its worth like 10hp or something? Is there a problem having them with this set up I might go with?
Is it necessary to go with 1/2 inch ARP head studs for what I am wanting to do?
TIA
TIA
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
SSU'S Vice Mod
Originally Posted by Armageddon
normal ARP headstuds should work fine, go with a bigger turbo also.
I was looking @ ITS' 80mm the other day (tooling around their site), which flows compairable to a T88. I don't know what unit he's going with, but if it's that one, it's close.
Dish sounds fine. Go larger on the turbo. Nothing smaller than TV frame, or a pair of big T4 twins. You'll thank me later when it's nosing off at 5000 with the ITS turbo because the exhaust is being choked off.
Thanks
Shouldnt a T80 be able to support 1000rwhp? When you say go bigger is it because it will take less boost to get there or make more max hp?
Should I run gas ports or no?
Originally Posted by SStroked 410
Thanks
