STS and kenny brown subs.
Old May 11, 2005 | 09:18 AM
OWENMUSTANG's Avatar
Default STS and kenny brown subs.
is anybody using the STS turbo with kenny brown subframe connectors?
looks like the pressure side pipe goes right where my subs are....
thanks
Old May 11, 2005 | 09:35 AM
Angie's Avatar
thanks
You won't be able to run a driver's side subframe with the STS kit.
Angie
Old May 11, 2005 | 09:43 AM
Blackbird's Avatar
I am. I just cut away part of the sub and rewelded.
You can still use most of it.
So now its basically a mix of the sub and the charge pipe that STS says sorta replaces your subframe connecter.
Old May 11, 2005 | 09:59 AM
99SS-T's Avatar
So ya call that a IC/SFC pipe??? lol
John
Old May 11, 2005 | 10:04 AM
John
thinking i might have to do something else....
Old May 11, 2005 | 10:16 AM
Blackbird's Avatar
no I call it still using the subframe connector which was what the question asked was.
Old May 11, 2005 | 10:52 AM
so, your using the c.a.c pipe for a subframe connector?
any pics?
Old May 11, 2005 | 11:34 AM
Fryguy302's Avatar
any pics?
Believe it or not, that kit DOES use the discharge tubing as a subframe connector. At least the one I saw did.
Old May 11, 2005 | 12:03 PM
I would love to see a pic of this...
btw, how's the racing been?
boosted99camaro's Avatar
yes the intake pipe is also a sub frame connector pritty good one too i use that on drivers side and slp subframe con.on pass side but you could also do as blackbird did use your subframe conn. and weld the intake pipe to it.
