Too much boost :(
Old May 7, 2005 | 03:40 PM
TA Dave's Avatar
I hope that was the only problem. You could try it short term until you can get another pulley. You'd just have to make sure you got it exact or it could add vibration to the bottom end.
Old May 7, 2005 | 04:14 PM
Third Gear's Avatar
Holy **** Ed, you crazy **** . Hopefully that was the problem right there... keep us updated!
p.s. if you wanna see how things are looking, you could do an oil analysis, that would tell you if you have excess amounts of metals... although I still haven't gotten my kit yet, and if the noise is still that pronounced then you know what it is...
Old May 7, 2005 | 04:17 PM
greentahoe's Avatar
Originally Posted by Ed Blown Vert
OMG found the problem. Crank bolt back out and sheared the pins on the MMS pulley. Any idea where I can get another one? Or do you think I can just put bolts in and reuse it?
MMS Pulley
Thats awesome man, I hope thats all it was. Keep us updated!
Old May 7, 2005 | 06:53 PM
Ed Blown Vert's Avatar
Looks like that was the problem. No more knocking. :whew:
No Knock
Went for a part-throttle run. Pulls great for 5#'s
Time for another MMS pulley. Or the 8 rib set-up.
Old May 7, 2005 | 07:23 PM
JMBLOWNWS6's Avatar
Cool. But when the time comes here what I am getting done for that price.
CRANKSHAFT: STOCK (Would like it repolished)
RODS: Callies (Compstar) H beam 6.125
PISTONS: Diamond reverse dished
RINGS: Diamond
BEARINGS: Clevitte 77 rod and mains "H" bearings with Durabond cam bearings
ARP bolts and studs
That will include all oil galley plugs & dowel pins
for all parts and labor listed above, balanced rotating assembly, and finnal assembled
Old May 7, 2005 | 09:49 PM
Third Gear's Avatar
Sweet, great news Ed!
Old May 7, 2005 | 09:54 PM
Bad30th's Avatar
OMG Ed, I'm gone for one day and I miss all the drama !!!
SOOOOOO glad to hear it was only the pulley. What a relief ! My mouth was hanging open until I read the second half of the thread !
I'll give you a call tomorrow.
Cheers,
Rob (Bad30th)
P.S. I won 1st place 82-02 modified Firebird at the SCC POCI All-Pontiac car show today !
Old May 7, 2005 | 10:08 PM
You can't believe what a relief it was. Its even more fun to drive. Now its time for another dyno and see if I can give it a bit more timing.
Congrats on the Win! Did the Procharger help?
Old May 7, 2005 | 11:12 PM
TA Dave's Avatar
Ya Ed, get some new dyno numbers.
Side note, you two may know a friend of mine out there, Jim (Old Man) Taylor. Long time racer in SD, with two GTO's...
Old May 8, 2005 | 09:29 AM
Got Me SOM's Avatar
how did you fix the crank pulley?
Old May 8, 2005 | 09:39 AM
kp's Avatar
kp
MMS Pulley
You can just tap it and put some grade 8 bolts through the front and loctite them in. Liiks like crap but good luck finding and MMS pulley. If your crank isnt pinned now is the time to do it. The balancer not being pinned will let the bolt loosen up, once the bolt loosens up the pins will shear off soon afterwards. If its already pinned never mind
Old May 8, 2005 | 11:45 AM
  #32
I put the grade 8 bolts through the holes and used two nuts on each bolt to hold it.
Old May 8, 2005 | 02:56 PM
  #33
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Pin it foo!
Glad it was not a bearing.
Old May 8, 2005 | 04:44 PM
  #34
BoostedWS7's Avatar
man the same thing happend to me like a year ago...yup the bolt just backed out.
it had me upset just like you. glad its all good now. loctite dat biotch!
