Too much boost :(
Old May 7, 2005 | 01:12 AM
Ed Blown Vert's Avatar
Default Too much boost :(
Heads
Finally got the heads installed. Changed the pulley from a 4.10 to a 3.70. Set the tranny to shift @ 6200 instead of 6800.
Went for a test run. Hit 10# of boost @6800.
Check the tune and adjusted it again for 6200.
2nd run, hit 8# of boost @ 6300. Then started to hear a little knock. I am guessing a rod.
Timing was still set @ 17* and no detonation.
I'll post a clip of the noise tomorrow.
Old May 7, 2005 | 01:49 AM
GhostZ's Avatar
Ouch....best of luck.
Old May 7, 2005 | 02:02 AM
618HAWK's Avatar
Were you runing a stock bottom end???? How many miles????
Hope it is not that bad, .
Old May 7, 2005 | 06:25 AM
mdhmi's Avatar
8 to 10 #'s on a P1 sounds reasonable to me. You using good fuel?
Mark
Old May 7, 2005 | 08:31 AM
greentahoe's Avatar
I wouldnt think youd have any problem running 10# on a stock bottom end as long as your tune was good. Where you running a WB at the time? Did you go lean?
Did the heads up your compression? What is it at?
Old May 7, 2005 | 08:41 AM
ktmrider's Avatar
Dang Ed, so sorry to hear the bad news, especially considering the wait time for the heads. Keep us up on the happs.
Old May 7, 2005 | 11:31 AM
Heads were 71 cc, so CR should have been around 9.5. Alot better than the 11:1 I was running. I don't think I went lean. I scanned the whole run without any detonation.
Still on the stock bottom-end with 87k miles. I knew I was going to have to get a new forged bottom-end but was hoping to have it last a little while longer.
Knock
Old May 7, 2005 | 11:45 AM
TA Dave's Avatar
Damn Ed, Sorry to hear that.
Probably a combination of things, 6800 RPMs, 10 lbs of boost and a stock bottom end.
Old May 7, 2005 | 11:55 AM
JMBLOWNWS6's Avatar
Man ED Im sorry to hear that. I took the long road and went ahead and got my bottom end forged. Taking a little longer than I wanted it to but I guess its worth it. SDPC gave me a great deal. Your looking at about 2200 + shipping using the stock crank.
Old May 7, 2005 | 12:00 PM
Does it sound like rod knock? Could it be the valvetrain?
$2200 isn't that bad. I was planning on $6K for an installed forged shortblock. But if I can get away with my crank all the better.
Old May 7, 2005 | 12:17 PM
TA Dave's Avatar
It's higher pitched than what I'm use to, but I've never lost a rod in an aluminum block to judge it by.
I'd check the flexplate before you pull the motor.
If it's in the valvetrain you should notice a miss in the exhaust note.
Old May 7, 2005 | 01:06 PM
Flexplate? Check it for what??
I pulled the driver-side valve cover, everything seems to look ok. The sounds only seems to come from the front driver-side.
My guess is still the bottom-end.
Old May 7, 2005 | 01:08 PM
TA Dave's Avatar
Stock flexplates tend to crack between the bolts, and sound just like a rod knocking. That's why SFI plates are req'd for NHRA.
It's probably the bottom end, but I like to check the easy things first.
Old May 7, 2005 | 01:25 PM
strokedls1's Avatar
Pull the valve covers and check the springs out. I have seen a bunch of springs break right off for whatever reason.
Old May 7, 2005 | 01:38 PM
Gotcha...
Driver-side springs look ok. And that seems where the sound is coming from.
Old May 7, 2005 | 01:48 PM
ninobrn99's Avatar
you mean we gotta get dirty again when you wanna pull the tranny? All I can say is that 10# run was the ****!!! Too bad all that work went down the drain
Old May 7, 2005 | 01:51 PM
You know what? I am going to double check the crank pulley just in case it got loose.
Old May 7, 2005 | 02:47 PM
OMG found the problem. Crank bolt back out and sheared the pins on the MMS pulley. Any idea where I can get another one? Or do you think I can just put bolts in and reuse it?
MMS Pulley
Old May 7, 2005 | 02:48 PM
ninobrn99's Avatar
Good call!! Hope that is what was causing the knock. Let me know how it goes.
