Low Rpm Part-Throttle Knock
EFI
But going 21 mph, TP @ 30% Engine turning 2600 rpms. No boost. No load. The extra air is going to affect it? Then why by giving it more throttle the knock goes away?
Sure I can bring in PE sooner or pull timing. I just want to make sure that is the correct way to solve this. Thanks.
also your VE is going to be very different now and when that is way off it will produce seemingly random KR in all sorts of conditions.
This is the fun stuff I am learning from Rick@Synergy and Heath. The tuning being done on a lot of the car leaving Rick's shop are reporting MUCH improved throttle response and overall driveability because of the tuning done in places most tuners would not touch. I never really though much about part throttle either but after seeing the differences I am convinced. I had similar problems with my turbocharged 4x4 and through street tuning we corrected it. All those often overlooked cells do mean something.
Every car I tune gets a complete tune, driveability and power.
I'm surprised your seeing that much knock at that point since it's not very high load. What i've found is that once I can tune ALL the knock out of a motor I can then increase the timing A LOT more everywhere else.
Once knock starts, it's almost impossible to stop.
Being able to hold a car at 200rpm increments on the dyno is awesome.
I'm sure you'll get it sorted out with some data logging on the street Ed and she'll be back to normal but with some extra kick.
Can a mod move this to the PCM tuning section?
Would it be better to pull timing? Or bring in PE sooner? Since I am not in boost, I would think timing.
Sweet.. I asked Rick to chime in here about it and when I mentioned your problem he said the PE sooner thing. LOL Good to hear it's fixed
