Pusher Fans
Old May 9, 2005 | 10:48 AM
TJ's Avatar
TJ
Default Pusher Fans
Hey what are the strongest pusher electric fans that you guys use with the turbo right behind the radiator? Or what is the strongest you've herd of? I dont have much room between my radiator and intercooler. I had to move the radiator forward some and it is straight up and down. Thanks
P.S. its on a 94 camaro
Old May 9, 2005 | 12:07 PM
CHRISPY's Avatar
SPAL makes a good pusher fan (You will need two)
I can't remember the part number, hopefully someone else can chime in
Old May 9, 2005 | 12:09 PM
mongse's Avatar
I ruin the end of films...
I'm using twin Trimline 114s from Flex-A-Lite. In hindsight, I could've went w/ a pair of 394s, but oh well.
Old May 9, 2005 | 12:18 PM
Armageddon's Avatar
...with cheese.
Flexalite 140's you'll need two or get the pair of them, not sure the #
http://www.summitracing.com
Old May 9, 2005 | 01:38 PM
HellRaiser's Avatar
FAL #240 Its 2 12" fans in one unit. Cost 209 @ jegs or summit.
Old May 9, 2005 | 03:21 PM
TJ's Avatar
TJ
So does anyone know what the cfm is on the stock fans?
Old May 9, 2005 | 04:14 PM
RICE ETR's Avatar
Turbo Addict
I think the stockers with shroud are like 3200-3400cfm.
I got the spal fans referred to above (Thanks Chris!) for about the same price.
Old May 9, 2005 | 08:16 PM
99SS-T's Avatar
Anyone knwo the largest pusher we can get in there? I am takin out the AC radiator so i got a little mroe depth room but same width and height.
John
Old May 10, 2005 | 11:33 AM
stevieturbo's Avatar
Another flow related question.
Would one large single fan, be better than 2 smaller fans ??
I have 2 x 10" fans, staggered on my radiator, but If i leave it to idle long enough, the temperature does creep up more than I would like.
I think I could squeeze a 16" single fan in instead, again pushing. Dont have room for a sucker fan. In theory the 16" should cover a much greater core area, than the 2 smaller fans, which would probably be better even if the fan actually flowed less ???
Does that make sense ?
Old May 10, 2005 | 01:17 PM
mongse's Avatar
Do you have a shroud or are the fans just on the radiator?
Old May 10, 2005 | 01:34 PM
With me blowing from front, thru the rad, no shroud.
No real room for a shroud either. I dont think you would put a shroud on a blow through application anyway ??
Current setup.
Old May 12, 2005 | 03:57 AM
CAT3's Avatar
Restricted User
Yes pusher fans benefit from a shroud, helps create a venturi effect to increase the velocity as well as directs the flow onto the specified area.
Old May 12, 2005 | 11:08 AM
Wouldnt a shroud around a pusher fan only restrict natural airflow through the rad once the car is moving ??
Old May 13, 2005 | 04:12 PM
Blackbird's Avatar
the air is going to take the path of least resistance.
without a shroud guess where that is.
over, under, to the side, but not thru the radiator where you want it.
the shroud is a must if you want any chance of it being effective.
