General Turbo Power Question
Old May 11, 2005 | 01:00 PM
2xLS1's Avatar
Default General Turbo Power Question
Asking this for a local turbo shop that doesn't do much LS1 stuff but put turbos on lots of other types. They want to know if 500 RWHP is do-able on a stock heads/cam/bottom end LS1 car and if it would live very long. The key word here is stock. They seem to think they can fab up the necessary turbo, but would the car need at least a cam or anything else and would it live.
Old May 11, 2005 | 02:31 PM
chris's ws6's Avatar
Yes, you can get 500rwhp on a stock car on pump gas as long as it's tuned properly. You don't need a cam or anything. The only thing that you would need is aftermarket valve springs, the stock ones will float.
Old May 11, 2005 | 03:09 PM
777's Avatar
777
and some better injectors
Old May 11, 2005 | 03:12 PM
sb427f-car's Avatar
SSU'S Vice Mod
Depends, yes, they might run into float then again they might not. 777 is right, injectors and TUNE TUNE TUNE!!!! Definately go intercooled too!
Old May 11, 2005 | 03:18 PM
y2khawk's Avatar
Pump and injectors, ~8 psi on a stock motor w/ intercooler will get you there in an M6 without problem.
I ran at that level and higher with good fuel for 24k+ miles before pulling the motor to go w/ a built motor and head/cam. Never had the valve covers off before that. Other than more than normal ring wear for a 40K mile motor everything looked great
Old May 11, 2005 | 03:19 PM
Armageddon's Avatar
...with cheese.
Hey Harlan, you got any 2-steps you havnt sold yet?
Old May 11, 2005 | 03:21 PM
y2khawk's Avatar
none done, but I did put you on the list for the clearance sale
Back on topic
Old May 11, 2005 | 03:46 PM
2xLS1's Avatar
Thanks guys. Any tips on what to tune WOT timing and a/f on a 8 psi intercooled setup to make a stock LS1 live?
Old May 11, 2005 | 03:56 PM
y2khawk's Avatar
<= 11.5 A/F
Keep the timing in the low to mid teens around peak torque (usually about 4800 w/ a stock cam). You can ramp up to high teens almost 20 between peak torque and peak power/fuel cutoff.
Each one's a little different, but that should get you close.
Old May 11, 2005 | 04:00 PM
Armageddon's Avatar
...with cheese.
Originally Posted by y2khawk
none done, but I did put you on the list for the clearance sale Back on topic
cool lemme know
