Got started!!
Old Jun 3, 2005 | 08:41 PM
  #61
Warbird's Avatar
Originally Posted by KAOS
man that is close to that pulley. frcefed is yours that close?
edit: looks as though msds are the only wires you can run with this kit, true or false?
Kaos it is close to the mine is exactly the same, as an added safety feature my crank is now pinned, if that bolt backed of it would take out the whole turbo system and most of the front of the motor. HellRaiser, I would consider doing the same, inexpensive insurance.
I am running Taylor wires, this kit has pretty good clearnace between the headers.
Old Jun 3, 2005 | 08:44 PM
  #62
KAOS's Avatar
so you think thunders relocation would work then
Old Jun 3, 2005 | 09:06 PM
  #63
frcefed98's Avatar
i was wanting to use thunders relcation set up but oh well
Why can't you? I have the Thunder Racing coil relocation kit on my car as well? Just get a set of LT1 MSD wires, hack the ends off and build the wires with the MSD multi directional boots like I did...a lil time consuming but nothing is stopping you from running the TR coil relocation kit.
J
Old Jun 3, 2005 | 09:08 PM
  #64
frcefed98's Avatar
On the passenger side...the driver side clearance sucks.
I had the taylor 10.5mm thundervolts on my TR kit, had to toss em in the garbage as 3 of plug wire boots were resting on the header tubes on the driverside.
Old Jun 3, 2005 | 09:24 PM
  #65
frcefed98's Avatar
Originally Posted by sscam68
Jer has the new bracket.
Still waiting for a full pass!!
I'll be test fitting it tomorrow morning. Pat pm sscam68 about it.
Frank, but you did get a taste of 8psi....how well do you think this turbo spools
A full pass will be yours once tuning is done
Old Jun 3, 2005 | 11:01 PM
  #66
SScam68's Avatar
Felt pretty good, started to pull like your ATI setup.........then you let off . I'm still in aww at how docile it was especially with that cam. It was a helluva lot louder with the SC setup.
Hey, isn't this Hellraisers thread?!?!
Old Jun 4, 2005 | 07:55 AM
  #67
HellRaiser's Avatar
It's all good. This info is good for me to.
sscam68 I will send you a pm.
Old Jun 4, 2005 | 08:26 AM
  #68
SScam68's Avatar
You're going to love it.
I'm sold, but more than likely I'll be designing and building my own kit.
Old Jun 4, 2005 | 10:13 AM
  #69
NA$TY-TA's Avatar
bad *** good info to know even if you dont have the Phamspeed kit..... im sure ill forget and have to PM you Jer anyways..
Kyle
Old Jun 5, 2005 | 03:57 PM
  #70
HellRaiser's Avatar
Well I drilled and tapped the oil pan today. I got he pan off and back on without hoisting the motor up or dropping the K-member. It was very tricky but easy at the same time. I just unbolted the oil pick up tube thing then slide the pan out. After drilling and tapping I slide the pan back into its place and very carefully manage to bolt back up the tube. Theres not much of a gap to work with but it can be done. then bolted the pan back up. I think this way will only work if you have the trans out as mine is right now.
Old Jun 5, 2005 | 05:26 PM
  #71
Warbird's Avatar
Nice work HellRaiser, however do us a favour and clean the thing next time
Are you considering pinning the crank?
Old Jun 5, 2005 | 06:30 PM
  #72
HellRaiser's Avatar
You know I did wipe it down pretty good. But at this point I just want the car back on the road. I don't know how long this stock motor is going to last either. What is pinning the crank? Do you think I will even have a problem, I never took the crack off so I would think its on there pretty good.
Old Jun 5, 2005 | 06:51 PM
  #73
Warbird's Avatar
My concern is the very close location of the turbo flange to the crank, we are both the same in that regard. If your balancer were to ever backs off, which could happen under the high stress loads you will see, you will loosee turbo and motor at the same time. Pinning the crank is pretty cheap insurance and will make sure that doesn't happen.
Pinning the crank is when they put a notch in both balancer and the end of the crank, they then insert a keyway that holds it in palce. If anything ever backed off the keyway will hold the balancer in place. The crank can easily be installed on a lift with the motor in the car, you will have to upbolt your turbo first for room.
JMHO, but I think it should be a must with our kits.
Old Jun 5, 2005 | 09:00 PM
  #74
HellRaiser's Avatar
Is there any pics of it on here?
Old Jun 5, 2005 | 09:07 PM
  #75
frcefed98's Avatar
Should be some pics. I pinned my crank and crank pulley when I had the engine going together. I really did it because of the stress the supercharger put on the crankpulley and the RPM's I was turning the engine to(7200). Is it needed on a turbo application? Probably not, easy to do for you....yes and no, No because you have the crossover and exhaust housing bolted up, but yes cuz all you need to do is drop the crossover to get to the crank pulley.
A few companies make em, ATI Procharger, ATI superdampners, and a roots blower company...forgot the name of it.
J
Old Jun 8, 2005 | 08:19 PM
  #76
HellRaiser's Avatar
Well I am getting close to being done! All I have to do is fab up the ic pipes,get my flywheel resurfaced and install the new clutch,put my gauges in, and last, pull the valve covers off and find the bad rocker arm.
Old Jun 8, 2005 | 10:19 PM
  #77
frcefed98's Avatar
Getting there...you'll be amazed at how quick this turbo spools Thats all I can say....I can't wait till I get this fuel bug sorted out so I can keep my foot in it. Can't believe the difference between this GT42 and my ol D1-SC.
Old Jun 9, 2005 | 04:23 AM
  #78
KAOS's Avatar
lookin good
Old Jun 9, 2005 | 07:28 AM
  #79
Warbird's Avatar
Looks awesome Hellraiser
Judging by you front facia, you might want to add a skid plate as your next mod. That piping hangs way below the scratches
Old Jun 9, 2005 | 07:43 AM
  #80
White.Lightning's Avatar
Looks good. I think the piping will be fine if you are at stock height. You figure the wheels/tires will go over a speed bump or any other "obstacle" and prevent the piping from being caught on anything. I still need to get to your house and check this car out. I might as well wait until it is running so I can get a ride!!!! hehehe. Talk to you later.
Andy
