pt88 pics
Old May 17, 2005 | 01:40 PM
RealQuick's Avatar
nice!!!
Old May 17, 2005 | 05:29 PM
parish8's Avatar
single digit dreamer
that waste gate pipe is only 1 3/8" , i may not be able to control the boost with the cut out open. i will be turning the boost controler all the way down and opening the cut out to see where it goes, if it goes over 17psi then i may have a problem.
i am going to the track in kc on friday. i am no longer welcome at the local track till i get some safety equipment. i dont expect a new best or anything, still have lots to figure out. i might be hiting the dyno this weekend too but if not the next weekend for sure.
not sure what elbow you are asking about. the inlet is 5", the outlet is 3", the down pipe is 4". the 5" rubber elbow came with the original kit from cmotorsports and they made me the new down pipe too. there is no way a 5" will fit in there unless i just dump it by the tire.
Old May 17, 2005 | 07:39 PM
gnx7's Avatar
Awesome..... Can't wait to see some video of the passes.
That is with a 5.3 liter truck intake manifold? Does the 6.0 liter differ?
Thinking about doing an LS1 swap into my '84 LandCruiser FJ60 with a 4L80E. No turbo though.
-Mark
Old May 17, 2005 | 09:11 PM
1CAMWNDR's Avatar
Sweet Mother of God. Would you see any benefit going to a LS6 or Holley intake manifold? I wonder if the FAST would handle that boost.
Still on stocK 6.0 heads?
That **** is awesome . I 'd like to have a truck like that only with a Richmond 6 speed manual swap .
Old May 17, 2005 | 09:32 PM
Project GatTagO's Avatar
Can someone say Hot Rod Drag Week?
Andrew
Old May 17, 2005 | 10:39 PM
parish8's Avatar
i have the stock truck manifold and stock 6.0 heads. i hope to step up to some good heads before the year is over.
my bov is still opening right at the 2-3 shift. i tried the adjuster on it and it made no difference at all.
my min boost with the cut out closed is 15psi, and with it open it is 22psi , seems the waste gate really isn't large enough. i seem to be able to fuel it at 22psi so i think i will just work around it rather than fix it. maybe with more meth i will be ok at 22psi but if not then i will only open my cutout when i have good gas in there.
drag weeks sounds bad ***. i am going to try and do it.
Old May 18, 2005 | 05:40 AM
smokinHawk's Avatar
are you sure the inlet for the turbo isnt 4" not 5"
you should definatly step up to a bigger wastegate
Old May 18, 2005 | 06:18 AM
parish8's Avatar
ahh, yeah, i think you are right.
Old May 18, 2005 | 06:52 AM
GhostZ's Avatar
Man that's weaksauce!!!
Old May 18, 2005 | 07:44 AM
1CAMWNDR's Avatar
Originally Posted by parish8
.....drag weeks sounds bad ***. i am going to try and do it.
I really hope someone has a good video camera there .
Old May 18, 2005 | 08:50 AM
Diolar Magnum's Avatar
RIP April 14, 2008
From: the land where cars repeatedly hit my bumper when I'm in the store...
looks great and MAN I wish I had that much acreage under my hood!!
Brad
Old May 18, 2005 | 09:41 AM
  #32
maddboost's Avatar
Have you called and talked to the guys at PTE about what wastegate setup they recommend for you?
Old May 18, 2005 | 11:17 AM
  #33
Vaka-Mon's Avatar
damn thats hot dude.........nice and clean
Old May 18, 2005 | 11:23 AM
  #34
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
For the PTE88 use the Progate. PTE will recommend the HKS GT more then likely. But you could buy almost 2 of any other gate on the market for the price of the GT...lol
Old May 18, 2005 | 11:43 AM
  #35
Camaro_Zach's Avatar
damn you and all that room you have in that truck! lookin HOT man. gl with the new setup!
Old May 18, 2005 | 03:59 PM
  #36
MIGHTYMOUSE's Avatar
i would like this turbo lined up next to a
turbonetics y2k, a gt45 and a gt 42. i dont care what flanges are on it, i just cant fit any thumper under the car without removing the front swaybar.
thanks
Old May 18, 2005 | 05:07 PM
  #37
parish8's Avatar
i may not do anything with the wg. if i can get enough meth so i can run 22psi then i wont have a problem. i think i can get it there.
mighty, this may help.
i think these in order are a thumper88, gt47, pt88, t67
Old May 18, 2005 | 09:15 PM
  #38
parish8's Avatar
ok, i am prety sure i am making more power than i was. i just broke my level 5 4l80. it sure felt good right up till it let go. my log file shows me hitting 7500rpm when it let go but everything seems to be fine. i have a lot of passes on this tranny and within a few runs with the new turbo it let go so i see that as progress in the power making goal.
Old May 18, 2005 | 09:45 PM
  #39
1CAMWNDR's Avatar
Damn! And I was hoping for a track video!!
Bummer on the tranny , hope you get something lined up soon.
Old May 18, 2005 | 10:58 PM
  #40
BlueSix's Avatar
Parish, when you do make it to KC let me know. I'd love to come out to KCIR and watch that beast run.
