unintercooled boost limit?
Old May 19, 2005 | 09:04 PM
whynot's Avatar
Default unintercooled boost limit?
I have heard that on lt1's you can run 6 psi unintercooled and 9 psi intercooled, but that is with 10.5:1 compression, but I just built the bottom end with forged pistons and rods, with 21 cc dishs, giving me a cr of 9.25:1, what would be my limits on intercooled and unintercooled on pump gas.
Old May 19, 2005 | 09:54 PM
ddnspider's Avatar
no intercooler on a forged motor is stupid,and with a FMIC you should be good for 12-15 psi
Old May 20, 2005 | 12:54 AM
Blackbird's Avatar
my brothers mustang is 9.5:1 and he has been running 9psi non intercooled for years. 20+ degrees of timing to boot. runs great no issues. you certainly wont get the max out of your setup non intercooled but you can do it.
Old May 20, 2005 | 06:01 AM
tici's Avatar
Think about alkyl... I see a difference of 100F using 8 GPH water/ethanol 50-50.
6 PSI, 12.5 AFR, 24* timing and no KR.
New dyno numbers in a week or two. In my sig it was with 10.5 AFR and 21* timing.
This could be an alternative to an IC, don't you think?
Old May 20, 2005 | 09:19 AM
Blackbird's Avatar
sure can. I ran my ATI setup that way at 10psi.
SJH had his vortech running that way at 13psi!
Old May 20, 2005 | 05:18 PM
whynot's Avatar
I plan on throwing an intercooler in after a mounth or so, I just want to get some track time in now that I have gone from a supercharger to a turbo, and I don't want to push it to much, So I figured since most people on hear know what they are talking about I would try to get my ?'s answered, it looks like 9 is safe unintercooled, anyone else?
Old May 20, 2005 | 08:00 PM
ddnspider's Avatar
on ls1's its about 6-7 so....
Old May 21, 2005 | 06:46 PM
whynot's Avatar
no, this will be on an lt1 with 9.25:1 cr not the stock 10.5:1 or the 10:1 that the ls1's have.
Old May 21, 2005 | 07:45 PM
ddnspider's Avatar
plus your working with an iron block so you should be good for 9 id think
Old May 22, 2005 | 10:40 PM
seal's Avatar
i have an LT1 with the same compression as u do (built as well) i'm running 5psi unintercooled and 11psi with methanol
Old May 22, 2005 | 10:55 PM
SSprayn's Avatar
my dyno numbers are in my sig and I have no intercooler and run 10 psi.
Old May 22, 2005 | 10:58 PM
S_J_H's Avatar
And I'm in the process of going back to that setup.
Steve
Old May 23, 2005 | 03:35 PM
ls1charged's Avatar
9-10 psi is good.
Old May 23, 2005 | 07:47 PM
whynot's Avatar
SSprayn, are you running 10 psi only when you are spaying? and what is your compression ratio?
Old May 23, 2005 | 10:46 PM
SSprayn's Avatar
I don't have nitrous on this car. I got the screen name from when I had my old car and joined the board. My compression ratio is 9.2:1
Old May 24, 2005 | 11:19 AM
White_Hawk's Avatar
I was getting 6-7 psi on my stock shortblock with a powerdyne, but I could only get ten degrees of timing out of it at peak torque.
-Geoff
Old May 24, 2005 | 11:55 AM
DAPSUPRSLO's Avatar
Lt1 also has a bigger bore which may make it more proan to detonation then a ls1 (both stock bore ofcourse).
Old May 24, 2005 | 07:24 PM
whynot's Avatar
oh, I overlooked the first car in your sig, and thought it was the mods on your lt1, so what do you have done to your lt1, if you don't mind, I am just trying to figure roughly what I am going to have when I get it on the street?
Old May 25, 2005 | 10:43 AM
SSprayn's Avatar
^ its a 396 LT4 block. 4 bolt mains AFR cylinder heads, th400 tranny, strange 12 bolt and vortec T trim with custom made 10 rib setup running 10 PSI for now
Old May 25, 2005 | 12:02 PM
HUGGER ORANGE SS's Avatar
Non Intercooler will be okay for your LT1 396, However Keep the Timing low..
I would buy a Meth kit and install it..
Clint
