AFR or Allpro heads
Old May 25, 2005 | 10:35 AM
MIGHTYMOUSE's Avatar
i need the most strength and stability i can get... my turbo makes the hp.
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Originally Posted by DERTY
The top side also has an increased height to allow for larger spring seats to get cut in without punching into the runners. The clamping areas of the head are reinforced further to help get some more mass in those areas.
The coolant jackets are smaller as well. This tightens up the area above the spark plug holes where the head likes to lift the soonest, especially when boosted. And like Brad indicated, they can be configured to order with more options. This makes some of the part selection for those heads very nice.
I like these two points, I have already run into the first point as a problem, my seats broke thru and I had to have the heads worked on.
Old May 25, 2005 | 11:09 AM
RyanJ's Avatar
SSU Moderator
Out of the box, obviously the AFR's are better...especially for N/A apps on the street (smaller port, better flow, CNC machined). However, if you are going to port or customize the head to you app...All Pro's hands down.
mongse's Avatar
I ruin the end of films...
When I get home, I'll post the info I got from Bob @ AP back in January. Very interesting numbers.
Old May 25, 2005 | 11:57 AM
1997 vet's Avatar
That will be helpful. Thanks
Old May 25, 2005 | 12:10 PM
sb427f-car's Avatar
SSU'S Vice Mod
Would 20 CFM on a blown application really amount to much? Also, where is the 20 CFM difference? If it's outside the "fat" part of the curve, I seriously wouldn't worry about it and then buy on whatever features you are attracted to with either piece of hardware. Good luck, and interesting thread btw.
Old May 25, 2005 | 03:24 PM
1997 vet's Avatar
The 20 cfm are through the whole range.
Old May 25, 2005 | 04:20 PM
blackz93's Avatar
Originally Posted by JZ'sTA
If you have 3,500 dollars to spend the All Pro's can be a FANTASTIC Head.
I thought they were 2400??
Old May 25, 2005 | 04:34 PM
Squintz Palladoris's Avatar
Originally Posted by smokinHawk
i believe the all pros have that 3/4" deck as well.
Their site says 3/4+
2400 will get you a complete set of heads with MINIMAL work done to them.
Like a CNC Chamber and some bowl work.
Add a grand to that for some nice porting
For some this will be an awesome head to get because they flow well un ported. But you can grow into the other features later on down the road.
AFR has a nice Head! but for an all out Race application I see AllPro as having more potential for makin the Power.
Brad
Old May 25, 2005 | 09:59 PM
mongse's Avatar
As promised...
http://www.quarter-mile.net/images/AllPro.gif
For the downloading impaired...
All Pro Hurricane 230s, 4.155" bore, NO PIPE on exh, 2.02 int. valve, 27.5* backcut
Lift # Int. Exh.
.200 138.1 107.5
.300 205.0 165.3
.400 249.6 204.2
.500 278.6 218.2
.600 284.6 225.3
.700 282.1 227.9
AFR's 225 Mongoose (per their '05 master catalog), 4.125 bore, 1.875" pipe on exh., 2.08 int valve, unknown b/c
.200 150.0 120.0
.300 220.0 178.0
.400 266.0 220.0
.500 304.0 241.0
.600 320.0 250.0
Either way, both very good heads.
Old May 26, 2005 | 12:53 AM
CAT3's Avatar
Restricted User
Ok, now how do you compare these ( I Know not the same bench but...) since the Bore is different, pipe etc????
Old May 26, 2005 | 10:13 AM
  #32
1997 vet's Avatar
On the Corvette forum someone posted the flow number in the tech section for the AFR 225's and they were very close the the Allpro's. They were going to get more info on the flow data but it is interesting.
Old May 26, 2005 | 10:23 PM
  #33
mongse's Avatar
That's really the ONLY way to accurately compare them. I know Kurt was working on something, so I'll wait for those results.
Old May 26, 2005 | 10:26 PM
  #34
KissMySSo1's Avatar
Well theres a flow chart right there. I Love how people say ALL PRO's hand down when they have probably never seen a set in there life. AFR obviously flows alot more out of the box. But there is alot more porting you can do on the AFR's then just the factory CNC. 400+CFM can be easily obtained with some more porting. No one knows anything about the ALL PRO's yet
Old May 26, 2005 | 10:43 PM
  #35
i know this:
1/4- 8.12@172 <-- ALL PRO heads
Old May 27, 2005 | 12:18 AM
  #36
I know all I need to know.
Brad
Old May 27, 2005 | 12:30 AM
  #37
gator's 99TA's Avatar
the set of AP heads i have seen down in FMS looked great. again the ohio boys seem to have their hands full with them.
Old May 27, 2005 | 01:25 AM
  #38
CAT3's Avatar
Restricted User
Look Junior, not taking to kindly to your ignorant reply. You obviously know less about WTF your talking about then you think we know. You say there is a flow chart right there, referring to this...
Lift # Int. Exh.
.200 138.1 107.5
.300 205.0 165.3
.400 249.6 204.2
.500 278.6 218.2
.600 284.6 225.3
.700 282.1 227.9
.200 150.0 120.0
.300 220.0 178.0
.400 266.0 220.0
.500 304.0 241.0
.600 320.0 250.0
Now Mr. Know-It-All...I again ask the rhetorical question, but you obviously didnt pick up on the sarcasm, how can someone begin to compare these two flows listings? The Answer is you cannot. There is insufficient information, what flow bench? Weather? There were way different standards, AFRs advertised flow, compared to an independent flow, no cool to compare. Also, look at the specs of how these heads were flowed...one no pipe, different bores, different valves, and God knows what else. And...if you bothered reading through some of the subjects on All Pro's you would see where several of the people that are regulars here use, have used All Pro's, so there are plenty ppl that have seen them and used them to give opinion. I hope if any newb is reading any posts from you, they understand you may be giving out bad info and potentially screwing someone over.
MM, get your APs and run some deep numbers man.
I personally would like it if the APs could start out in a 76ss, but seems the largest is 72cc. I need a lil lower compression when I swap heads
Old May 27, 2005 | 04:16 AM
  #39
Nate_Taufer's Avatar
and i believe the all pro flow numbers are "as cast" with no cnc work done. so you could expect a **** ton more flow when you add in cnc work. take flow numbers for an as cast 180cc AFR head and compare. then we're talking apples and apples.
Nate
Old May 27, 2005 | 04:59 AM
  #40
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
How did this discussion end up on the FI forum? H/C guys need great heads to be competitive, but turbo or S/C guys can make great numbers with crap heads. I know, I know, the best is the best, but if anyone on here were really that competitive, they wouldn't have time to hang out on an internet chat board!
