AFR or Allpro heads
Old May 27, 2005 | 11:42 AM
  #41
mongse's Avatar
I ruin the end of films...
Originally Posted by taufern
and i believe the all pro flow numbers are "as cast" with no cnc work done. so you could expect a **** ton more flow when you add in cnc work. take flow numbers for an as cast 180cc AFR head and compare. then we're talking apples and apples.
Nate
I hope you're kidding.
but if anyone on here were really that competitive, they wouldn't have time to hang out on an internet chat board!
So true...so very very true!
Most 4th gen guys are so in love with AFR's stuff because that's all they've ever had for an option. Hell, I've got a set of big ones on my car (in hindsight, I should've put a set of 18X's on, but what can ya do?). What other options have there been? Canfield? I'd have a better chance of finding Tupac alive than getting a set of those. Trick Flows? Not a big improvement over factory castings. Eddies? Nah, I'll pass.
Old May 27, 2005 | 11:48 AM
  #42
JL ws-6's Avatar
Race your car!
sad when the factory castings ended up being so good that the aftermarket world is having a tough time coming up with offerings that really make it worth while... the afr and allpro are the only real options at this point... the afr's are a great bolt on head, and the allpro is looking to be a great "racer" head, with possibilities that are really open to the end user.
I'm dying to see what a set of allpro's set up for n/a are capable of, but noone's done a set yet as far as I know. Hell, not too many people have even done them at all at this point.
Old May 27, 2005 | 12:02 PM
  #43
mongse's Avatar
You know, when I saw a local guy hand port his heads and get 330 out of them, I wondered the same thing. There are always improvements to any design, it's a matter of whether making those improvements will bring in revenue.
I forgot to add ET Performance's heads that are supposed to be out this year. I wanted to stop and talk to Cary @ WFC, but figured I'd be strung up for talking Chevy heads at a Ford event.
Old May 27, 2005 | 12:07 PM
  #44
gator's 99TA's Avatar
mongoose. my canfield lt1 heads have a core shift issue. epoxy is holding teh SOB together at this point larry meaux did all he could with them.
Old May 27, 2005 | 02:40 PM
  #45
XIII's Avatar
Originally Posted by KissMySSo1
Well theres a flow chart right there. I Love how people say ALL PRO's hand down when they have probably never seen a set in there life. AFR obviously flows alot more out of the box. But there is alot more porting you can do on the AFR's then just the factory CNC. 400+CFM can be easily obtained with some more porting. No one knows anything about the ALL PRO's yet
My grandpa used to say its better to be quiet and allow people to think you are stupid than open your mouth and prove them right.
400+ CFM is not easy to obtain. No one is anywhere close to it.
Old May 27, 2005 | 02:55 PM
  #46
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I just spit coffee all over my computer screen... lol.
Old May 27, 2005 | 07:10 PM
  #47
john go clean that up now.
Old May 27, 2005 | 07:17 PM
  #48
JL ws-6's Avatar
Race your car!
400 isn't gonna be easy regardless what head it is... it's still a small block head.
The all pro's with the possibilities, would be a more likly candidate to being able to hit that # then the afr's simply beacuse of the added mat'l on the top side of the head.
Old May 28, 2005 | 05:22 AM
  #49
70 TA's Avatar
Some pics I took of All Pros we got delivered on Wednesday
http://usera.imagecave.com/camarojoe/AllPro/
Old May 28, 2005 | 08:44 AM
  #50
DAPSUPRSLO's Avatar
I take it that's the cnc chambered head. Doesn't look like any other porting was done to them though.
Old May 28, 2005 | 10:43 AM
  #51
1997 vet's Avatar
What are the heads going on? Will you run them as cast or are they going to be ported? Also why did you chose those over the AFR's? Sorry for all the questions. I am ready to order my heads and I am still trying to decide which to buy.
Old May 28, 2005 | 11:38 AM
  #52
MIGHTYMOUSE's Avatar
hers my thread... in the right section
https://ls1tech.com/forums/showthrea...80#post2980080
Old May 28, 2005 | 12:38 PM
  #53
70 TA's Avatar
The chamber comes CNC'd, I am not sure what CC they are at.
Other than that them ports need to get hogged out big time
Old May 28, 2005 | 01:25 PM
  #54
mongse's Avatar
That's why I'll keep them where they belong...a museum.
400cfm is a LOT of air. I've seen a set of Little Chiefs pull those numbers and a set of 2.2s come real close, but NEVER a 15* head, let alone a production head.
Old May 28, 2005 | 08:50 PM
  #55
CTSmechanic's Avatar
I have had my All Pros for a few months now . they look bitchin sittin on top my tool box. I gave them to a friend to do the finish work on them valve jobs clean up the ports stuff like that.Hopefully I'll have some numbers mid next week... When your gettin something done for free you cant be to pushy..
Old Jun 30, 2005 | 06:46 PM
  #56
GMC SKI's Avatar
Any updates on these Heads fellas?
Flow numbers Dyno numbers Butt-o-meter numbers
Old Jun 30, 2005 | 06:51 PM
  #57
Race Car Driver's Avatar
11 & 7 Second Clubs
AFR's here, but we are talking about two peas in a pod, as they say in the South.
Originally Posted by 1997 vet
I am looking at getting a set of heads for my engine and would like to know who is using Afr or Allpro heads. Which is better and why?
Old Jun 30, 2005 | 07:42 PM
  #58
1997 vet's Avatar
I decided on the All Pro heads. Looking at the two heads the All Pro heads are a much stronger casting. Look at the part where the rockers mount. I think if I were going to run a N/A engine then I would have went with the AFR's due to them being cnc'd for about the same price.
Old Jul 1, 2005 | 10:25 PM
  #59
Cary@Perf-Induction's Avatar
Collections Hold
Default 400 cfm
We are already there with our cylinder head.
In race trim our Cathederal port head is 403 cfm@ .750.
2.150 intake valve on a 4.125 bore. 50 degree seat.
2.100 on a 4.00 bore was 376@.700 45 degree seat 265cc
2.125 valve 4.100 bore was 386@.700 45 degree seat 266cc 357@.550
1.570 exhaust valve 282 @ .800 with a 1 7/8 pipe. 248 no pipe.
Old Jul 2, 2005 | 05:07 AM
  #60
JL ws-6's Avatar
Race your car!
Those are impressive #'s for sure. How do the heads flow on a stock bore.... or are these heads only for large CI applications? Other then wanting the absolute best head on the market.. I really don't have my heart set on anyting yet.
Also, your heads... if used on a stock CI motor, what kind of cam are you reccommending.. how big is needed to maximize teh flow rates of the heads? Port size for smaller CI any different?
