Update on my project
Old May 25, 2005 | 04:33 PM
Warbird's Avatar
Default Update on my project
Great work from Autoworks on putting it together and building the car and great fab job from Phamspeed
The car is finally coming together and getting close
Work remaining - Fab inter cooler, body shop for nose modification, install battery, install fans, tune and engage warp speed
Old May 25, 2005 | 04:40 PM
99SS-T's Avatar
Sweet. I hate to break it to you the duct tape wil not survive . Lol Looks great man. What size turbo ya put in there? I jsut finished mine the other day and after i get the valve springs in ill be hittin the dyno again. Hope ya make some sick power. GL
John
Old May 25, 2005 | 04:48 PM
LTLHOMER's Avatar
Autoworks = new ARE name?
Old May 25, 2005 | 04:50 PM
HellRaiser's Avatar
Is that a t88? Looking good.
Old May 25, 2005 | 04:51 PM
Warbird's Avatar
LOL I am missing the V-Band for the downpipe so we taped it up for location. One of those little things that just need the time to drop by the truck stop to pick up
The turbo is a PTE T88 .96 AR housing, full tubular 65 thou stainless headers. The 4" downpipe needs to be compressed for ground clearance and the intercooler will sit behind the bumper with the appropriate body modifications for breathing
Old May 25, 2005 | 04:58 PM
HellRaiser's Avatar
Stock motor? You were one of the guys that had big problems with the other kit right? about a year or more ago? I hope this kit works out for ya.
Did you have a problem with the BMR k-member hitting the phamspeed exhaust manifold?
Old May 25, 2005 | 05:01 PM
Warbird's Avatar
Yes I'm the guy that had his motor let go on the other kit with lots of imaginary problems . This motor is a 391, forged internals with 8.0:1 compression.
It's not a BMR K-Member, it was built by Autoworks (ARE) perfect fit and no notching needed. The K-Member is chromemoly and powder coated.
Old May 25, 2005 | 05:03 PM
99SS-T's Avatar
Missed your post lol. That turbo should flow 1200 or so HP right? GL
John
Old May 25, 2005 | 05:06 PM
Warbird's Avatar
Originally Posted by 99SS-T
Lol a .96 housing will be about 10 psi out of it efficent range on a stock motor. What HP you plan on running when you break teh stock motor and forge the new one? That turbo should flow 1200 or so HP right? GL
John
Not a stock motor, I'm looking for 750 on pump gas at about 12-14 lbs. The motor is sleeved stuuded and braced and should be solid for race at 18-20 lbs. I have no idea what it can make on race fuel and high boost. I do know an auto is in my future
HellRaiser's Avatar
I was thinking if the motor was stock then the turbo was way big but you have the motor. Car should put up some sick number for ya. good luck.
Old May 25, 2005 | 05:10 PM
Warbird's Avatar
I'm trying out a new fuel system for this set up that should be interesting. It has a dual pump with boost sensitive regulator and full return off the rail. Base fuel pressure will be set around 50 psi to allow it to idle with pressure increasing with boost (Effectively increasing injector sizing). I'm also using the 60 lb Motoron injectors.
Old May 25, 2005 | 05:14 PM
MIGHTYMOUSE's Avatar
good to be back in the game, isn't it?
Old May 25, 2005 | 05:18 PM
Scalpel's Avatar
Turbos always look bad ***.
Old May 25, 2005 | 06:07 PM
Warbird's Avatar
It's great to be back for sure . Just wait till you see the new nose
Old May 25, 2005 | 06:29 PM
RyanJ's Avatar
SSU Moderator
ARE? Really?
Looks good. Make sure to show some pics when you get it on the ground and stuff.
Old May 25, 2005 | 06:40 PM
White.Lightning's Avatar
What kit is this? Looks nice ***Edit: Read first post= Phamspeed kit*** haha
Andy
Last edited by 0fbody0; May 25, 2005 at 06:41 PM. Reason: I read the first post! DOH :)
Old May 25, 2005 | 06:41 PM
Warbird's Avatar
It's a Phamspeed kit, on the hot side, Autoworks on the cold side
Old May 25, 2005 | 08:24 PM
onfire's Avatar
Coal Mining Director
That's a nice set-up Warbird. What size intercooler are you going with? I wonder what's the largest front mount that will fit in the nose of a bird.
Old May 25, 2005 | 09:16 PM
NA$TY-TA's Avatar
cool...... you going to be using the stock PCM??? Who's going to tune it??
kyle
Old May 25, 2005 | 10:17 PM
Warbird's Avatar
Onfire,
Were going to run the biggest intercooler we can stuff in the front, not sure at this point what the actual core size is going to be. I know the car won't make the kind of power a Meth/Alchy set up might make, but it will likely be more street friendly.
NA$TY-TA,
We will be using the stock PCM. Autoworks will tune the car on their dyno, they have all the needed gear to do a good job. I believe they are going to use HP Tuners for the job. The software is very versatile and there are a couple of options to try. We might even try speed density tuning to eliminate the MAF altogether. I do want to try it with the MAF and see how far we get. If using a MAF it will be a draw through style.
