STS time-8 psi-6 SPEED
kjm, If I could pull a 1.6 60' I would solidly be in the 11's, but with the amount of wheel spin I had made a huge difference. As the car sits, 11's are coming soon, but I need to figure out why my mph is so low. Once I figure that out, low 11's should be really attainable. And, this was at 8 psi, I wasn't sure if your post just had a typo.
Side comparision, mine stock bottom end baby cam setup went 11.84 at 14.7 in my stalled auto(3000 stall) without a tune vs a 13.1 at 112 in my buddies 6 speed, stock geared, no tune car(he now owns my old motor). 6 speed vs auto can make a big difference.
By the way Billy, you were 100% correct about fatherdome!
Peak power is at 5000rpm and he probably hits peak boost at 3500rpm.
This means that he is essentially only running at peak boost for 1500rpm before the power falls dramatically, and I would be willing to bet that he is shifting near 6k (where he is making no power at all).
As mentioned earlier, peak power/tq doesnt mean as much as how broad the power curve is.
made a new stell gasket fixed my problem i take it you ran at maroso we should meet up and race
I am in the process of installing my STS setup (GT67) and plan on going deep 11's on 5 psi, high 10's on 8psi.
