STS time-8 psi-6 SPEED
60' 1.945
1/4 12.265
mph 116.61
And I had a ton of wheel spin of the line. I think I needed to warm up the Mickey T's a little bit more. Unfortunately, I only got one run tonight, but it's a step in the right direction. And this is a 6 speed, no auto to load the motor on. I think I can get this thing to hit hi 11's as it sits. Just need some more seat time!
Course these are just observations from lurking on this board mostly.My turbo experience is from my turbo awd dsms. But hope to turbo my 99 ta shortly.
I am definitely excited with the progress...before the 2 step and tires I couldn't get this thing to launch at all. I kept pulling 2.4x 60's. What kind of 60' do you think I would need to pull to get the 11's?
400 rwhp heads/cam/header car can do 116mph and he gets around 12.2 with 2.18 60fts in his SS at 1900 feet altitude . With extra 100 hp your mph should be well past 120. Not sure whats happening up top.
Guess you just have sorting out to do..did you change tuning much since the dyno..are you pig rich now up top?
Anyway I would still be very pleased to have your setup and sure there is lots of room for improvement.
Enjoy your toy!!
And, even though I have the 2 step, I only launched the car at about 2 psi. Again, if I had more than one run I could have adjusted that as well. What was weird about that is I had tried the 2 step earlier, and at the same setting I hit 6 psi. This time only 2??? So I am also going to check to see if I'm bleeding off boost anywhere.
Get the bugs worked out and you should have a very solid 11 sec car.
-Bryan
-Bryan
I agree...warm em up more...cant get em too hot can ya???
-Bryan
361hp/412tq thats 114 hp and 83 ft/lbs less than you.....1.639- 60ft., 4.796- 330ft. to an 11.90@112mph on the same M/T drag radials you are running. 18psi and a *decent* burnout. Full weight. Something is def. wrong.
