suggestions on turbo cam
Old May 28, 2005 | 08:32 PM
Sn8ke_Eater's Avatar
Default suggestions on turbo cam
i did alot of research on turbo cams but can't decide which one i want. i will be running a 6.0l motor, 6.0 heads with exhaust ported, sts turbo gt70 with fmic 3.23 gears for faster spool l vig3600 built 4l60e for know and racetronix plug and play and 60lb inject looking for street and track drivability with 8-13lb of boost.
Old May 28, 2005 | 08:44 PM
sr71's Avatar
try the one you have in your sig. I reused my sc cam and it works well. I am afraid to change anything for fear of slowing it down.
Old May 29, 2005 | 09:52 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I tried a forward split and a reverse split. I think you'd like a reverse split better -- I do.
My cam: 236/230 .600/.600 115lsa.
Old May 29, 2005 | 10:15 AM
thanks for the info guys but i sold my other cam already but i like TurboBerserkers cam specs i might do that any body else.
Old May 29, 2005 | 11:26 AM
ddnspider's Avatar
LPE GT2-3 i have and have been told that it will work very nicely...or try an MTI sleeper cam.
Old May 29, 2005 | 07:30 PM
thanks for the info will look into that
Old May 29, 2005 | 09:19 PM
xssive's Avatar
Mine is 236/232 .609/.609 on 112.
Old May 29, 2005 | 10:08 PM
Z06PSI's Avatar
I was wondering about this the other day. In the boosted how to section stickied the article stated that your turbo cam's lift should be 10% higher than where the head makes the most flow. It expalins about using the valve opening as well as a the valve closing to pack as much as possible in the cylinder. If this is true then a high lift .610-.630 cam should be used with a head that reaches peak flow in the .580's... Am i on target with this? I am getting ready to choose a cam here soon and the LSA is done and the duration is still a sketchy but I will settle for this conversation first. I am building a max effort car for the track.
Old May 30, 2005 | 08:18 PM
i am confused i heard small cams work better.
Old May 30, 2005 | 10:08 PM
Z06PSI's Avatar
Small by duration or lift..???
