BeCool dual fans...
Old May 31, 2005 | 06:04 PM
Bad30th's Avatar
Default BeCool dual fans...
Is this the one folks are using with ATI kits ? Anyone using one with good results ?
BCI-75007
Brand: Be Cool
Product Line: Be Cool Radiator Electric Fan Kits
Flow Direction: Puller
Fan Quantity: Dual
Maximum Fan CFM: 2780
Number of Blades: 5 blades per fan
Height (in): 16.313
Width (in): 23.500
Thickness (in): 4.250
Blade Material: Plastic
Blade Color: Black
Shroud Color: Black
Shroud Material: Plastic
Amp Draw: 25.0
Thanks,
Rob (Bad30th)
Old Jun 1, 2005 | 06:34 AM
JIMMYZZ28's Avatar
Are those actually the spal twin setups? If so we move them all day long here at Griffin and they are great. The blades are rigid and dont deflect and the motors can operate at higher static pressure without problems like some manufactures.
Old Jun 1, 2005 | 08:47 AM
Bad30th's Avatar
Thanks for the reply.
I think these are the same as the Spal fans, but want to make double-sure before ordering so I thought I'd post. They're 4.25" deep which is what I read is a good fit...
Thanks for any advice guys.
Cheers,
Rob (Bad30th)
Old Jun 1, 2005 | 04:34 PM
Bad30th's Avatar
TTT one time - need info !
Bad30th
Old Jun 1, 2005 | 05:39 PM
Blackbird's Avatar
you seeing those on summit? price is just under $300? if so then yes those are the spal being marketed by be cool and work quite well. still not good as stock but probably 85% as good.
Old Jun 1, 2005 | 10:05 PM
Bad30th's Avatar
Yep, that's them...
I'll prolly order them tomorrow.
Think this will allow me to run the A/C in summer traffic or is that pushing my luck ?
I had an "overheating episode" over Memorial Day weekend in 5 1/2 hrs of summer heat and bumper-to-bumper traffic. I have since re-routed the BPV to atmosphere instead of into the blower inlet, and am looking for a better fan setup to help the car stay cooler on cruises and such.
Thanks fellas !
Rob (Bad30th)
Old Jun 1, 2005 | 10:16 PM
Ferocity02's Avatar
Are these fans supposed to mount the same way as the ATI fan and shroud, using the 4 tabs? Also I hear the driver side fan needs to be ground down a little to clear the head unit. Let us know how it goes!
Old Jun 1, 2005 | 11:05 PM
Ed Blown Vert's Avatar
Let me know what you find out Rob, I may want to do the same thing.
Old Jun 2, 2005 | 12:45 AM
Blackbird's Avatar
what I did was drill 2 holes in the top lip of the radiator and mounted them to that.
then on the bottom I literally took a metal yard stick, cut it to length then slide it in the tabs where the stock fans where and it ran accross the bottom of the spals holding them into place.
yes you will need to grind down a tiny section of the part that shrouds the blade on the drivers side.
you will also more than likely need to lift the radiator up out of it's mount and push it forward to make room for the fans. it's tight but they fit just fine.
30th, it will get you close but if you really wanted to be 100% sure I would add a smaller set of slims to the front of your AC condensor, hook em to a switch and kick them on when needed. 95% of the time you wont but you will be glad your not in traffic on a hot day with no AC that other 5% of the time
Old Jun 2, 2005 | 08:57 AM
Bad30th's Avatar
Nice, thanks for the info !
When I get around to installing them I'll try to take some pics and post a writeup.
Cheers,
Rob (Bad30th)
Old Jun 2, 2005 | 12:24 PM
Avengeance's Avatar
On the bottom you can also use a tranny cooler mounting kit. Thats what I did with my SPALs. All it is is zip tie looking dealios that go through the original SPAL bottom mounting holes with a washer.. push them through the radiator and condenser fins and then on the other side you put a tab that slides down and locks on. Theres even little spacers that go between the shroud and radiator that keep it from rubbing and damaging fins. I think it cost me like $8 from a local speed shop.
Old Jun 2, 2005 | 12:29 PM
Blackbird's Avatar
the only problem with that is then that fan is in there semi permanatley.
i unfortunately had a need to take the blower in and out a bunch and that wasn't gonna happen with the fans in there.
using the bar made it simple to remove them when needed.
just something to keep in mind.
