intank vs external pumps
i have a stock rearend and am not looking forward dropping it to get to the tank or cutting the trap door. would an external pump be enough? I'm not looking to go higher than that psi this season, and id upgrade the pump next season when i get a rear-end.
Jeff
1) Small inline pump (like what ATI sells with their kits)
2) Voltage booster on the pump. Only get a kit that increases the fuel pump voltage under boost. Do not get a kit that increases the fuel pump voltage all the time.
Either of the above will safely get you through to next season.
