60lbs injectors and a PT-88
What is the largest injector a stock PCm can handle..?????
The biggest injector without molesting the injector circuit of the stock PCM/driver is around 70 lb/hr. You can get away with RC Engineerings 75 lb injector, but it requires some trickery with the programming. I run 75 lb injectors on the stock PCM/driver.
Kevin who did you get them from??? the injectors i mean..... and if ya dont mind how much??
Kyle
only thing i heard bad about high impedance inj's is something about the duty cycle being f'ed up or something, i cant remember what it was that was negative i heard about them...
And from most calculations thats not taking in drivetrain loss ..... so are we talking around 700rwhp......
I know Mightey Mouse did 800rwhp with his Motrons 60#ers, but he was also using 80 psi of fuel pressure and Meth.
Kyle
It's definitely a less than ideal situation, but it is possible.
