AFR 205 or AFR 225 ?
Well, the 225 requires cutting to the piston. If you don't mind that the 225 will be the better choice. If not the 205 would be good to. You may want to check out some of the offerenings from ET Performance. New stuff comming out with thick decks, better flowing ports, and comparably priced.
So when i use the 225 i must cutting the pistion ?
Originally Posted by BoostedWS7
why must you cut the piston with 225's?. ive never heard that.
Originally Posted by RW99
That's the first I've ever heard that ANYTHING other than Cometic gaskets is necessary to fit AFR225 72cc heads to a stock 346. Fact check? Anyone?
and i belive tony has said in several threads. cutting the pistons will be required...
Chrispy, good info. So I should be fine with 72cc (unmilled) 225's and a 224/224/114 cam on a stock bottom end, right?
If you are really concerned it is easy to clay and check.
