20PSI with 408?
Old Jun 9, 2005 | 12:01 AM
Bill Reid's Avatar
I've seen GENIII heads lift at 20+ psi (spike)... on 2 seperate occasions in 2 seperate street cars with F1R's... on 8.5:1 382/408 motors... both o-ringed... not that that matters... I think we're dealing with physics here.
At some point this is no longer about how much boost you can cram in... its about how much 4 bolts per cylinder can hold...
So if you happen to bang it off the rev limiter how are you going to keep the heads down?
You GENIII guys with 20+psi... how are you keeping your heads down? Street use apps please
Old Jun 9, 2005 | 01:32 AM
KissMySSo1's Avatar
700hp can easily be obtained on pump gas.
Old Jun 9, 2005 | 09:16 AM
Blown408's Avatar
Bryan, sent you a PM.
Thanks for the info guys. Keep it coming, The more I read the more I learn.
