Ideal Radix A/F ratio?
Old Jun 8, 2005 | 12:47 PM
Naked AV
Guest
Posts: n/a
Default Ideal Radix A/F ratio?
Curious about the ideal A/F mix for a Radix setup. As you can see by my plugs below (which had 36,000 miles on them), I've been running a little rich on the 'Stock' Radix Superchips tune. Both times I went to the dyno they measured below 10:1 until about 5100 RPM's, so I got a wideband ready to go in and start tuning. Just wondering what A/F I should be shooting for.
Attached Thumbnails Ideal Radix A/F ratio?-old-plugs.jpg   Ideal Radix A/F ratio?-new-old.jpg
Old Jun 8, 2005 | 12:54 PM
ACPromotions's Avatar
I might suggest that you go to LS1truck.com and post out for farmtruc, who isn't a sponsor on this board. He tunes Radix based GM trucks very regularly. If I had to guess, he would target between 11:5-11:9.
Old Jun 8, 2005 | 03:33 PM
kbracing96's Avatar
Um... Farmtruc is Allen Nelson I belive and he and his company, Nelson Performance IS a sponsor on this board.
Old Jun 9, 2005 | 04:55 AM
Naked AV
Guest
Posts: n/a
Thanks guys...
Anyone else have input?
Old Jun 9, 2005 | 05:15 AM
cablebandit's Avatar
i'd do 11:5 to be safe and then you can lean on it at the track to see what she likes
Old Jun 9, 2005 | 05:47 AM
Slowhawk's Avatar
LS1Tech Sponsor
It really goes by how much timing/intake temp.I like A/F around 11.2-1 on the dyno or 11.6-1 on the street but some heavy vehicles like your's like a richer 10.5-1 A/F to keep the heat down in the cylinder.
Old Jun 9, 2005 | 08:49 AM
hellbents10's Avatar
LS1Tech Sponsor
The radix trucks like to be in the low 11 range with the right amount of timing.
Old Jun 9, 2005 | 10:27 AM
Naked AV
Guest
Posts: n/a
A point more fuel just because my truck's heavier? Why is that? I'm confused.
Old Jun 9, 2005 | 11:12 AM
2001WS6Vert's Avatar
Just like a car will detonate more if your going up a hill. The more load, the more likely to detonate. The extra fuel helps to contain the detonation.
Old Jun 9, 2005 | 11:42 AM
CHarris's Avatar
I shoot for 11.2 to 1 across the band. I achieve 11.0 - 11.2 across the band. Works well for me. I've got 6800 miles on the H2 so far (most of them supercharged). No oil consumption at all (meaning I haven't washed the cylinders with fuel).
Old Jun 10, 2005 | 11:37 AM
ktmrider's Avatar
Bingo, these rolling bricks take quite a bit more torque ( or load ) to move around. This is why you want to tune for 80% to WOT instead of idle. No loads or small throttle opening doesn't need extra fuel.
The ultimate tuning combo is wideband and EGT probes. Adjust the A/F and watch the EGT's for excess heat.
I would let your KR to the talking, but definitely start out in the 11:1 to 11.5:1 range first. 10:1 is pig rich and probably leaving some power on the table too. Just getting your A/F in the 11's will probably net you 20-30 extra HP alone.
Old Jun 10, 2005 | 12:09 PM
Naked AV
Guest
Posts: n/a
Hmm, is there anyone who tunes using EGT's that you know of? I've never heard of such a thing.
