optimal turbo for 347
Old Jun 9, 2005 | 12:39 AM
StoleIt's Avatar
NKAWTG...N
Default optimal turbo for 347
what turbo would be the best for getting to 700+ rwhp on a built forged 347 with 6.0L heads and a turbo cam. i was thinking a t76 would do the job but might start running out of air at the top end. would a t88 or gt42 be better suited?
this isn't for me (i wish), but you know who you are!!!!
Old Jun 9, 2005 | 01:14 AM
KissMySSo1's Avatar
Go as big as posible.
Old Jun 9, 2005 | 05:19 AM
smokinHawk's Avatar
A T76gts would be best suited for that range
Old Jun 9, 2005 | 06:55 AM
Z06PSI's Avatar
I am picking up a PTE-88 for my 347, 6.0 headed large cam turbo setup... track only though and very light weight....
Old Jun 9, 2005 | 11:37 AM
2000 Tran Zam's Avatar
thats what im doing
Old Jun 9, 2005 | 11:38 AM
smokinHawk's Avatar
T106's for every one then!
Old Jun 9, 2005 | 11:41 AM
Z06PSI's Avatar
Old Jun 9, 2005 | 11:58 AM
ls1king000's Avatar
bigger isin't always better........but, i don't know **** about turbos and all that. SMOKINHAWK what do you think about 347-348 c.i. w/ 6.0 heads, turbo cam for a daily driver. like STOLEIT said he's looking for top-end, would just a larger turbo meet his needs ???? race only or street/strip????
Old Jun 9, 2005 | 12:27 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
For 700rwhp a 76GTS is all you need.
Old Jun 9, 2005 | 12:32 PM
eviltwins's Avatar
GT42-76, quick spool and 1000 RWHP potential.
Old Jun 9, 2005 | 12:39 PM
LS1TECH Sponsor
Same thing as 76GTS, just Garrett compressor cover.
Old Jun 9, 2005 | 01:00 PM
smokinHawk's Avatar
Old Jun 9, 2005 | 01:17 PM
Z06PSI's Avatar
What will be my approx spool rpm with the PTE-88 on my 347..????
Old Jun 9, 2005 | 01:36 PM
smokinHawk's Avatar
think Jose has stated something like 4000-4500rpm
whats your setup redumss? phamspeed budjet? what a2w IC
Old Jun 9, 2005 | 02:14 PM
LS1TECH Sponsor
A T88 will hit full boost around 4500rpms.
Old Jun 9, 2005 | 03:23 PM
StoleIt's Avatar
NKAWTG...N
what about a t76 on stock cubes?
Old Jun 9, 2005 | 03:25 PM
narcszm's Avatar
http://www.turbotechnologyinc.com/ls...ger_system.htm
LS1TECH Sponsor
It will hit around 4K.
Old Jun 9, 2005 | 03:30 PM
Z06PSI's Avatar
6.0Lmanifoldsbackwardsmyownspecial kit..... The A2W is the last thing I have got to get. It is a full drag setup though.
Old Jun 9, 2005 | 04:11 PM
mongse's Avatar
I ruin the end of films...
Only one? I'd run two up front and another rear mounted.
With as much air as these motors push, a GTS would be fine on a 347. There's guys running smaller cube motors w/ the same turbo and running just fine.
