Another 11 second STS car
Old Jun 10, 2005 | 03:07 AM
Zombie's Avatar
Default Another 11 second STS car
I finally did it after hot lapping the car a few times. Started doing burn outs on my last 3 passes.
11.774@123.95 [2.005 60']
also did a
11.895@123.25 [2.052 60']
More traction = more mph
Car is a 6 speed. Bald nitto drag radials. 10-13 psi depending on gear.
Old Jun 10, 2005 | 03:13 AM
MosesMcgregor's Avatar
also did a
any pictures of that setup??? STS with a FMIC?
Old Jun 10, 2005 | 03:25 AM
LSs1Power's Avatar
Nice times
Old Jun 10, 2005 | 05:47 AM
DarkblueTA's Avatar
Good times Jeremy! What was the DA out in Vegas last night?
So much for the STS haters saying "oh...it doesn't work"
Old Jun 10, 2005 | 07:05 AM
KraZy's Avatar
Wow, on stock motor?!
Congrats!
Old Jun 10, 2005 | 07:55 AM
quicksilverado's Avatar
Good job.
Old Jun 10, 2005 | 07:56 AM
NYSS Guy's Avatar
I was thinking the same thing...ON A STOCK BOTTOM END??? Maybe I need to turn up the boost!!
Old Jun 10, 2005 | 08:49 AM
RealQuick's Avatar
also did a
Did you leave with 0 boost? What rpm launch?
Old Jun 10, 2005 | 09:02 AM
boosted99camaro's Avatar
wow thats a great time with that 60ft.and nice mph too.are you running stock rear and what do you have for suspension and clutch.
Old Jun 10, 2005 | 09:11 AM
CHRISPY's Avatar
That is awesome for Vegas in the summer!
Congrats!
Old Jun 10, 2005 | 09:12 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
13 psi on the stock motor is definitely pushing it...lol
Jose
Old Jun 10, 2005 | 10:16 AM
Blackbird's Avatar
great job.
like Chris said remember is Vegas altitude and heat.
wonder how fast that would be near sea level?
low 11's????
Old Jun 10, 2005 | 10:25 AM
PurEvl's Avatar
Jose
you would know wouldnt you captain lt1
Old Jun 10, 2005 | 10:33 AM
Zombie's Avatar
Jose
Maybe I shouldn't mention I made 4 passes in 30 mins as well I was beating the **** out of the car. Made 11 passes from 10pm-12am.
I was hoping to get to 15, but ran out of wastegate spring first. It will only go 13 psi in 4th gear
13 psi is a moderate boost level. Thats all this waste gate spring lets me go with the boost controller set on kill (maxxed out greddy profec b spec 2). 10 psi is 28%. Boost is pretty much irrelevant as long as the car doesn't detonate or melt (crosses fingers). I get zero knock on this boost level except false stuff on the launch. Timing was 14 degrees at tq peak and 20 by 6k. Gas was a 60/40 mix of 100 and 91.
I'm really beginning to think people who run c16 in these cars at anything under 25 psi are wasting their money (if they have a good tune). In cool weather the car will run on this same tune on just 91 octane using 50/50 water meth, but when I know i'm going to beat on it i put some 100 in it. Since it's summer I have 3 less degrees timing and only run a max of 11 psi on 91.
I'm hoping the stocker will hold out for a while longer. I'm seriously thinking about doing lq9's, thicker gaskets and arp studs. Then the low boost will be 10 and high like 16-17.... or I could put the 50 shot on it
Old Jun 10, 2005 | 10:35 AM
Zombie's Avatar
Originally Posted by Blackbird
great job.
low 11's????
at sea level on a good night the car would go around 11.2 @ 129, maybe a little faster. Vegas conditions suck
The car is fun on highway rolls though, can you say bike hunting
Old Jun 10, 2005 | 10:57 AM
30th t/a's Avatar
wow thats impressive. what track did you race at?
Old Jun 10, 2005 | 11:26 AM
ktmrider's Avatar
Awesome times! At first I thought maxxing out at 13psi was a little low with the T67 but then saw you were in LV. Heat and altitude = less turbo efficiency. OK, gotta put this in here for the haters, the rear mount is also not as efficient either. Those of us running 5-10psi never worry about maxxing out tho....
Did some research on correction factors for altitude and F/I, you get half ( 1/2 ) the "normal" SAE correction value of N/A. Not sure your track specs but an extra 0.5 seconds or so quicker at sea level is about right.
Boost on!
Old Jun 10, 2005 | 11:29 AM
unit213's Avatar
Administrator
Just to **** in your wheaties, I went 11.50's (plus lid/catback) with a $500 nitrous kit.
Awesome trap speed!
Old Jun 10, 2005 | 11:36 AM
Blackbird's Avatar
sucks for you when you run into him with the bottle turned off or empty though now doesn't it
Good work Zombie, your motivating me to find time to get my **** together instead of it collecting dust.
Old Jun 10, 2005 | 11:38 AM
DarkblueTA's Avatar
now that's funny, I don't care who you are.
