Boost brainiacs........got a question
Old Jun 12, 2005 | 05:31 PM
Quickin's Avatar
Default Boost brainiacs........got a question
From what I understand, there are boost controllers that can be turned up and down on-the-fly, while you're driving.
If you have 93 octane in the tank for instance and you have the boost turned way down for daily driving, then you want to turn the boost up for more power, what happens when you do that with the 93 octane thats in the tank?
I assume there is just a limit to how high the boost can be turned up because of the octane.
So, what if a stand-alone tank were used with race gas in it so when you turned up the boost and nailed the pedal for a race it would be used to inject race gas into the intake.
Is there a system out there that does that or not?
Banks turbo told me that the boost on their engines, the 800, 1200 and 1600 hp twin turbo DART engines can literally be turned up and down to produce full boost (35psi) and as low as nothing and basically drive around on an all motor engine. Only problem I see with that is the octane problem.
With an injection system like a direct port nitrous system has, would that solve the problem with running around on 93 octane octane????
Old Jun 12, 2005 | 05:44 PM
Paulz2820's Avatar
yes alot of cars i've built have had auxiliary gas tanks like 4 or 5 gallons of race fuel. all you gotta do is get a separate tank, a pump, some fittings, some lines and wiring and you can push 1 button! that will switch the tanks over, turn up the boost, change the RPM, and timing map all with the push of a bottom. its all custom stuff i haven't seen a kit but its easily doable.
Old Jun 12, 2005 | 05:45 PM
NoGo's Avatar
I don't know of a plug-n-play system that accomplishes what you want. But you could easily put together something yourself that would accomplish that though......
Old Jun 12, 2005 | 06:27 PM
BOOSTNSS's Avatar
Default Alky control!!!!!!!!!!!!!!!!!
an alky can do this for ya just say 6 psi no alky 10-12 psi with single nozzle alky and up to 12-16 psi with dual nozz system the stuff works great
