maxing out a D-1SC
Old Jun 12, 2005 | 09:51 PM
liftin'em on nittos's Avatar
Default maxing out a D-1SC
i have a D-1SC head unit from an old setup with a mustang. i'm building a 360 ci or 383 ci LS6 motor now...solid roller, 7,000+RPM...is the D-1SC capable of delivering 18-22 PSI effeciently or is that to much to ask of it? i've heard that this particular head unit is capable of supporting up to 1200 RWHP and i don't think i'll get up in that area...~900-1000 is my goal. anyone with any feedback would be greatly appreciated. thanks
Old Jun 12, 2005 | 10:07 PM
2000 Tran Zam's Avatar
i think you might wanna go with an f1 if your looking to make that much power. thats all ive seen making it over 800 or so. i think the D1 is good for 7-800, but someone can correct me if they know any better.
good luck.
Old Jun 12, 2005 | 10:11 PM
tim99ws6's Avatar
Def. a F-series territory. Also gonna need a pretty trick belt setup to keep from slipping belt problems.
i figured the F-1 might be a better choice, but i already had the D-1 so i thought i would ask just for good measure.
Old Jun 12, 2005 | 10:12 PM
i was planning on utilizing a motor plate so the belt setup can be custom fabbed...it's still in the planning stages as of yet but it should materialize pretty quickly once i decide what to do for the FI portion
Old Jun 13, 2005 | 10:24 AM
blackz93's Avatar
D-1 is only good for 925 flywheel horsepower. F-1 is good for 1050.
Old Jun 13, 2005 | 10:39 AM
NA$TY-TA's Avatar
Yep just like they said..... D-1 is to small..... gunna need to step up to the F-1...........................
Old Jun 13, 2005 | 11:41 AM
NoGo's Avatar
Hell, if your changing superchargers and want to keep it 'close' to the same size go with an F1R.
The D1 will be too small for your goals. Good to between 7-800 RWHP maxed (depends on your static compression though).
If you are doing a custom belt setup Scott with SDCE has alot of experience with ATI D1R's (much bigger than F1.....aka 1500 HP) and is very good with belting a supercharger to stick. Keeping a belt on this thing is probably going to be one of your biggest hurdles.
Old Jun 13, 2005 | 05:18 PM
hmmm, well i called procharger today and got the info from them abuot getting an F1...they reffered me to HardCore for a belt setup but i think i'll call Scott with SDCE based on what i've see on here the last few days. thanks for the info guys. it's much appreciated
