temperature
Old Jun 13, 2005 | 12:10 PM
68ss_00ss_87_95's Avatar
Default temperature
installed a procharger and the new fan wont kick on, its wired correctly and the temp went to 235 and still nothing....it cycled on and off for a few seconds but doesnt maintain temperature anywhere lower then 210....where should i start?
Old Jun 13, 2005 | 12:12 PM
Got Me SOM's Avatar
nothing wrong with your sending unit?
Old Jun 13, 2005 | 12:18 PM
sending unit?
Old Jun 13, 2005 | 01:08 PM
Bad30th's Avatar
Coolant temp sensor, located in by the #1 cyl in the driver side head.
The sensor and wiring are probably OK if it's reading the temp changes.
Make sure the fan is pulling and not pushing and that there are no obstructions (plastic bags, etc) on the front of the radiator.
I've found out (the hard way) that it's common for the ATI kits to have cooling problems, especially if you have warm outside temps and/or you run the A/C. I am looking at the BeCool fans.
Also make sure your bypass valve isn't routed back into the blower inlet, venting it to atmosphere will provide a lot less heat back into the blower.
To test the fan, turn on the A/C. The fan should come on immediately. I'm guessing the problem lies in your wiring somewhere, or the fan doesn't work. If you manually put 12v across the fan does it spin ?
Cheers,
Rob (Bad30th)
Old Jun 13, 2005 | 01:14 PM
well the other day i ran it the air felt like it was being puched to the front of the car as if the fan was going reverse....i asked my electrician friend who installed that portion and he said it was wired right...ill have him bring his stuff over to check it out...i have seen the fan come on but with the a/c...no..i wasnt running the ac when temp was goin up and last time this happened i turned on the heater and the fan kicked on but this time nothing...ill check the fan wiring again, hopefully thats all it is
Old Jun 13, 2005 | 01:16 PM
Bad30th's Avatar
The manual has the fan wired backwards. Swap the wires so it pulls, not pushes. I betcha that's the problem.
Give it a try.
Cheers,
Rob (Bad30th)
Old Jun 13, 2005 | 01:45 PM
are you serious, the book is bass ackwards? heh...
Old Jun 13, 2005 | 02:17 PM
Bad30th's Avatar
True story.
Lots of people have had overheating problems as a result of the fan wiring diagram being wrong.
Cheers,
Bad30th
Old Jun 13, 2005 | 03:06 PM
just my luck, my electrician friend wired it wrong, the MECHANIC had to fix it...ty for the help it works fine now...
