DIY Alky Injection Kit
or is it a priming reseviour and the big tank is elsewhere?
plus you have no way to see when it's running low.
I would recommend a low level sensor or at least building it again using something clear.
After installing that, I'll buy some parts like you did and do my NOS SS to save some dough!
(By the way Snow is the cheapest store-bought kit I found...stage 1 is 299, Kennedy and Carrol Supercharging are around 500 and up maybe...)
Highly interested in your results...are you doing tuning/dyno results soon?
Yeah make sure you don't advance timing then run out of juice in boost! :O
The kits have leds to to mount inside the car to make sure the pump is working and alchy level is up- good safeties if you are going to advance tune for alky.
If you just use the windsheild washer tank ....then you have a dash light already as a safety.
Are you mixing methanol (20 Below) and water or are you just using Windsheild washer fluid, (nearly the same)?...
Keep us posted man!
