WTB 3.2 Procharger Pulley
Old Jun 17, 2005 | 08:45 AM
WHPLASH's Avatar
Default WTB 3.2 Procharger Pulley
Does anyone have a 3.2 6 rib Procharger pulley they want to get rid of?
Let me know.
Old Jun 17, 2005 | 02:48 PM
blu00rdstr's Avatar
I sent a 3" 6-rib Reichard Racing pulley to Andy at A&A corvette to play with. He might still have it. I'm running a 3.2" 8-rib RR on a D1SC and a great bracket setup, and still get slippage over 5500rpm.
Old Jun 17, 2005 | 02:54 PM
WHPLASH's Avatar
I just put a 3.4 and am only seeing 6.5lbs of boost (no slippage). I would like to get up to 8lbs. A 3.0 will put me above that.
Old Jun 17, 2005 | 06:34 PM
blu00rdstr's Avatar
If your crank pulley is 7.047", and your blower pulley is 3", that's a ratio of 2.349:1. So at 6,500rpm your blower pulley is spinning at 15,268rpm. The D1SC has a step-up ratio of 4.1:1, and the impeller will spin at 62,600rpm. The D1SC impeller limit is 62,000rpm, the impeller vanes will probably start stalling before that and start beating the air instead of compressing it.
Old Jun 17, 2005 | 09:14 PM
mdhmi's Avatar
Blu - how many pounds of boost are you making at 5500 RPM? It really looks like you need a larger pulley and a larger head-unit to get the power you want without trashing the belts.
Mark
Old Jun 17, 2005 | 10:17 PM
blu00rdstr's Avatar
Mark
I believe it nearly hit 14psi before it started dropping. Here's a video of the boost gauge and tach on the dyno: http://www.baseframe.com/dynos/dyno_atNewtech.wmv
Old Jun 19, 2005 | 09:09 PM
WHPLASH's Avatar
Ahhhhh. Does anyone have a 3.2 they want to get rid of???
Old Jun 19, 2005 | 09:28 PM
Jeremiah's Avatar
I have a 2.8, brand new in the box from Procharger if anyone is interested.
Paid $70 will take $35
