Main cap walk with aluminum block
Old Jun 19, 2005 | 10:20 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Looks like everyone is using the same girdle. I would like to see the W2W girdle, since I am more interested in providing my customer with a girdle that ties the mains in to the block directly. The girdles work quite well especially on the GN, since their weakness is in the mains and not the lifter valley like the Fords. Girdles on Fords are pretty much pointless to me, since that is not their real weakness. The one good thing about a girdle on the Ford's is, when they do crack in half at least it holds the block together from scattering...lol
Jose
Old Jun 19, 2005 | 10:37 AM
Public's Avatar
Originally Posted by Big Mike
That's not my car.
My mistake wrong Mike. I saw the link to his car and thought that's who you were talking about.
Old Jun 19, 2005 | 10:45 AM
Racehead's Avatar
It seems to me that the real advantage of the girdle would be to prevent block distortion, not cap walk, although it might help here too. One thing that might make a bit of differance would be to go with billet caps and studded mains including replacing the smallish side bolts with oversized studs thereby tying each cap individually to the block better and using the girdle simply to tie all the caps to one another. This would seem to help both block distortion AND cap walk ? Just a thought
Old Jun 19, 2005 | 11:38 AM
PurEvl's Avatar
That's not my car. My car is not together yet Inspector12. We should have it running by the middle of July. I am running a 9x.mm turbo and will be shooting for ~1600HP, using the girdle mentioned above. You guys will hear all about my setup once its up and running.
9x.mm always gotta out do me dont ya mike
Old Jun 19, 2005 | 01:14 PM
Big Mike's Avatar
Not trying to out do ya Mike, I'm trying to out do myself! Thats the story of my life.
Old Jun 19, 2005 | 05:56 PM
Inspector12's Avatar
TT-TECH Veteran
[QUOTE]The one good thing about a girdle on the Ford's is, when they do crack in half at least it holds the block together from scattering...lol[QUOTE]
Yes that is what I was told.
I would agree that there are a number of ways to make stronger girdles, but at what expence is all I am saying and the DM girdle can be used with billet mains I know Thunders will work not sure about everyone elses Billet main caps. Good luck with the setup Big Mike sounds like you are going to be running good.
Old Jun 19, 2005 | 06:07 PM
Mr. Bungle's Avatar
That's my car. I really liked that girdle it looks very high quality. Would definitly buy it again.
Old Jun 19, 2005 | 06:52 PM
Public's Avatar
For the Buick 3.8 and TTA 4.1 guys it keeps them from driving over their stock cranks and saves some blocks as well.
Old Jun 19, 2005 | 09:14 PM
smokinHawk's Avatar
i think the ohio boys mains did some walking when they were back on an aluminum block, before they switched to a w2w iron block
harlan of all people should be able to tell you how his aluminum block held up, think that one did ok cause didnt he put it in his truck?
not sure who made more passes but steve made quite a few with that aluminum block, when your at that level, its just a matter of time before things start to wear out.
Old Jun 20, 2005 | 12:28 PM
427's Avatar
427
Our girdle connects the mains to the block side skirts. We believe this offers the greatest block support to aid in main's stability in high output engines.
The side of the plate that touches the block has a o-ring groove for positive sealing. The lower side of the plate uses the standard gasket, although the hardware needs to be longer to make up for the plates thickness.
This system is only used in our most extreme high load engines.
There are three engines using them now.
Ohio boys racing. On the "Formula". Best ET 8.12 best MPH 178. dyno 1550hp
Mark, Con and Vic. On the Ute. Best ET 7.4x@ 18x. dyno 1570hp
My personal 5.7- In "Casper". Best ET 7.52@ 187. Dyno 1697hp
Scott Allen 6.6- Best ET "coming soon" Dyno "4 digits"
Kurt
Attached Thumbnails Main cap walk with aluminum block-girdle1.jpg   Main cap walk with aluminum block-girdle2.jpg   Main cap walk with aluminum block-girdle3.jpg   Main cap walk with aluminum block-girdle4.jpg
Old Jun 20, 2005 | 03:41 PM
Phate's Avatar
Kurt
Hey, what about me?
Old Jun 20, 2005 | 05:56 PM
  #32
TT-TECH Veteran
Kurt is that stainless or aluminum? Looks very nice I like the oring grove alot good sealing and preplanning on your part. I stated above that I believe that one that attachess to the skirts would be stronger. I Just don't think that DM one is going to be that far behind on cappabilities. How much further down does the oil pan come down did you have to modify the K-member at all? Is there a special procedure you are using on the line bores and then assembly etc...
Old Jun 20, 2005 | 10:02 PM
  #33
427's Avatar
427
Aluminum girdle. The pan moves down about .600. The cars we have used these on had tube type k members. All but Scotts had dry sump pans.
Scott does your k member clear?
We install the girdle in place, then align hone for final fit.
Kurt
Old Jun 20, 2005 | 10:13 PM
  #34
Phate's Avatar
Yep, my k-member clears, but it is also a tubular PA piece...not sure if it would clear the stocker.
Old Jun 21, 2005 | 12:24 AM
  #35
TT-TECH Veteran
Thanks for the information guys. Keep up the good R&D. Looks good Kurt.
Old Jun 21, 2005 | 01:34 AM
  #36
Jammer's Avatar
Me like iron
Old Jun 21, 2005 | 06:48 PM
  #37
bumpin_records's Avatar
Kurt
so when you say our girdle who do you work for and how can someone purchansed one if they want one cause yours look real nice compaired to the other one. and how much do they run
Old Jun 21, 2005 | 07:04 PM
  #38
69firebird's Avatar
Wheel 2 Wheel
Old Jun 21, 2005 | 10:08 PM
  #39
427's Avatar
427
Wheel to Wheel Powertrain is where I work.
We do not sell just the girdle as it is hard to install. We will install it on your block if you send it in. Call Billy @ 248-589-1190 for pricing.
Kurt
Old Jun 26, 2005 | 12:11 PM
  #40
N20Silverado's Avatar
Could somebody describe what main cap walk looks like? I tore down a used motor I bought (AL block) yesterday a noticed that the area where the main caps contact the block are discolored.
Thanks for your help!
Tim
