Main cap walk with aluminum block
JZ
Here is an example of the GN girdle....
Jose
Jeff
Jose
Jeff
Yep. The girdles do not work worth a **** on Ford 302 blocks. Even though it seems like it would help a ton, the blocks break in half at about the same power level, somewhere around 600hp, give or take.
I do know they've worked great for the buick guys.
Here's a car where they used a girdle... seems like a good idea, I'll probably end up doing it on my build up as an extra precaution... never thought about the oil pressure making it leak though... anyone else run into that problem?
is getting an FMIC and Meth system. He told me on Thursday he was delivering the FMIC to Ft.Wayne on Sat. They plan to turn it up a few more PSI after that and shoot for the 750 range. He's hoping to get it back next weekend tuned and finished.
That's not my car. My car is not together yet Inspector12. We should have it running by the middle of July. I am running a 9x.mm turbo and will be shooting for ~1600HP, using the girdle mentioned above. You guys will hear all about my setup once its up and running.
