What size downpipes?
In my opinion both of the sizes you posted are way to small..... **** twins GT42's...... with my single GT42 76MM wheel im running a 5" stepped to 4" and 4" all the way down........... why choke them like that???
2 1/2 pipe imo is to small for the 42's. 3" or larger for each if you are going to be using the realistic powerband of a pair of 42's.
Don't forget, any restriction on the downpipe means the turbine wheel has to work harder, which means unnecessary backpressure through the headers which means higher cylinder temperatures... and that equates to LESS POWER because you have to run more timing to avoid the higher risk of detonation!
Those are big-a$$ turbo's... I'd say 3" minimum.
Jose
