Monitoring Radix I/C and H/E temps
Guest
Posts: n/a
I'm replacing the heat exchanger that came with the Radix with a much larger one. At the same time, I'll be installing a water temp gauge. The question I have is - where should I mount the gauge sensor?
Should I:
Should I:
- Mount it between the output of the intercooler and the input to the H/E (perhaps in the reservoir), in order to monitor coolant temps before they head into the H/E
- Mount it at the output of the H/E, so I know the temp of the coolant prior to it heading back into the intercooler
