Supra vs. Camaro?
As a former supra owner it's not nearly as easy as you think, and they're not as slow as you think. My old car now has a T400 in it and with a 67mm turbo has seen 9's on drag radials. There are 45 listed single digit cars on supraforums and a lot of the owners post on there. I can understand why they get such a bad rap, but saying a 1000 HP supra can barely break into the 10's is flat out ignorant. Sure, they might be able to barely break into the 10's if they're running 19" rubber band street tires, but with even a modest 26x11.5 ET street bottom 10's from a 6-speed stock shortblock car are very attainable with some seat time. One guy on supraforums is running 10.5's with 670 RWHP in a very heavy street car, they do hook good when you don't have a gomer driving it.
hmmm, woon, saad, colby, so many to choose from,
i did race colby in his 542 rwhp 97 supra and spun a bearing in my motor.
oh well, im gonna get him when i get my car back, fo sho!
Thats the great thing about forced induction V8's. You can make bonzo HP on pump gas. The numbers in my sig is how the car is driven every day to and from work during the summer, on 93 oct pump gas.
I drool over supra's daily, but equate the race-gas situation similar to nitrous. JMO
I wonder if dyno charts would be more useful if they provided the average HP/TQ figures for a given RPM range, instead of the peak figures which are almost always misleading.
That's exactly what I was getting ready to say. These 4-6cyl cars CAN make the power but the area under the curve just is not there, your AVERAGE POWER is what makes a car fast in the 1/4 not PEAK POWER. You show me a 1500WHP Supra, and I will show you an 800WHP F-body that with equal traction will most likey slaughter the Supra! If you could put together a driveline that could keep the Supra at the 9000rpm it would take to make that much power, you could have a very fast car but the fact is, you really can't do it with any kind of efficiency.
-Bryan
You hit the nail on the head. Take a look @ their short and 1/8 mile times (while a factor of the IRS and chassis too) but this is what it boils down too. I rather make a very flat tq curve (or one that is making stout, rising numbers for a long time) and be able to make peak HP with in about 1000 rpm of peak TQ than make peak tq and hp on "top of the mountain" so to speak. That avg. hp and tq is what gets you down the track, along with having a useable power curve. I respect what those supras can do, it is very impressive, but the fact that the majority of heavy hitters never seem to back up track times where their dyno numbers and mouths are is where I lose my respect for them. I have a quote from a friend about Supras... "We don't know how fast that one is because we haven't found a set of rollers for him to race on yet." Give me a built 346, 350, 383, 370, or 408 on turbo boost over the 8500+ RPM and "peaky" #s a 2jz motor makes anyday, but, that's just because of who I am, and to each their own. Nothing like having a friendly rivalry between brands and approaches, just be able to back up the smack talk
. note: this isnt meant to say that an f-body with equal dyno wouldn't be quicker in the quarter, but merely to gain a little more perspective on the issue.
Define low boost on a 2jz motor though. What is that, 18, 20#s? Yeah, you're right, we're talking about two complete different "art" forms here. No one is disagreeing they make big power and can put up some impressive 1/4 #s, but that's with the right set up, a dang good driver, and usually the better portion of the #s come from 1/8mi on. Now, 8.2 on drag radials? Is this with a 4 link "back half" conversion because I have a very hard time buying an IRS has gone 8.2 in the 1/4 on a beefed up IRS. This would be very hard even with great conditions and an excellent driver to get the car to 60 and then 330 in order to put up that numbers. Please, correct me if I'm wrong, but I'm skeptical about that.
As a former Supra owner (and still a mechanic on them), low boost, IE: pump gas, is going to net you somewhere in the neighborhood of 550-600 RWHP, SAFELY. Thats ~17-18 psi. There will always be the fluke case, "My buddy dyno'd 7xx RWHP on pump" or the "we built one that laid down 650..".
Not safely you didn't.
I have hours upon hours of data logs from various setups that I have personally worked on and/or friends have shared with me. Like any engine, there is a timing cap you can safely get away with, day to day, pass to pass, on pump. With that said, there are a few people running meth injection and pushing the boundaries a little bit. However, there is not enough good data to see a long term trend with it.
Back to the point though, the narrow powerband is obviously not going to be much fun on the street. In a drag race though, they are staying in the powerband, so it's a moot point. There are a number of Supras running in the low 10's and a few in the nines that are street cars. Hell, there are 3 low 10 sec street cars in my neck of the woods. Marko's car is an extreme case, full weight, deep in the eights. That's not commonplace and the AAP car referenced above, is not a street car.
I didn't post here to stir up the pot, just to get a few of the facts straight. I spend more time reading on here than posting. My personal idea of a fun street car is an LS1 powered 93' RX-7. My TEA stage II's should arriving for it in two weeks (The obligatory "I like LSx motors comment"
)Ryan
I've read of stock bottom end SupTT's going low low 10's no problem.
Supras are very sharp cars, they are quite different from our F-Bodies. Supras are like heavy sports cars (to me) and F-Bodies are like plainer, muscle cars to me.
. The stock pistons I personally recommend as they don't slap and they work in concert with the oil squirters. The stock pistons have oil passages at the bottom of the piston which leads to an oil "hoop" cast into the piston itself. The hoop is located below the piston dome and works well at pulling heat out. The skirts are also coated with an antifriction coating from the factory. Up top, the cams start holding you back around ~600 RWHP. Cam upgrade with some stout springs will let you pull it to 8500 routinely. OEM headgasket is top notch. Those are the basics. I have some pics to compare with the LS1 as we debated the merits of both motors over at supraforums awhile back. Enjoy:My LS1 bottom end with a 2JZ main cap for comparison:
A stock 2JZ rod versus my Callies rod:
A Mahle piston vs the stock toyota piston (Note wrist pin dia.)
ARP head stud for my LS1 vs a stock Toyota head bolt (.638 and .601 respectively):
FWIW, the stock bottom ends will live for some nutty dyno pull #'s but don't get caught up in the hype. Start loading them down on the street at that power level and you'll be in line for a new shortblock.
Ryan
