Sts Problem.
Old Jul 2, 2005 | 05:01 AM
firehawk123's Avatar
Default Sts Problem.
Heloo,
i have problem with my sts kit.i install pistons and rods soo i can goo for more boost.the car was ok but after few days the oil level is going down when i race the oile leavel stay at 40 when i stop or drive the car at town the oil leavel is under 40 sometime its 30 or some time its 20 the gage leval. and the turbo dosent want to spin.befor that i was running 15 psi and when the rpm gose over 4500 RPM i hear some noise from the mice that is inside the car that comes with the sts harnes.
thanks for help,
iam sorry my engils is not good but i am traying my best to let you gays understand me and fixs my problem.
Old Jul 2, 2005 | 05:30 AM
Wolfee's Avatar
By level do you mean pressure at the gauge? Are you running a different oil than before, viscosity? Or maybe you have a broken piston and your sucking oil into the exhaust which is causing the turbo to not spool up properly. If this was the case though you would probably have huge plumes of white smoke. A simple compression test would probably help you out a lot in the diagnoses. That's what I suggest first. Wolfee
Old Jul 2, 2005 | 07:09 AM
turbo-max's Avatar
ummm....wow
Old Jul 2, 2005 | 05:30 PM
thanks for healp.yeas i mean the oil pressure but i dont think that i have broking piston because i gust install my piston and rods 2 weeks ago.i toke my car to the dayno and the car made 580hp at 15 psi at 5000rpm after that the AFR is running lean that why i stoped the car intell i get the mony for the fuel system. after that i drive may car and i loked at the oil pressure and i found it under 40 some one is tealling me that is the oil pump maybe is bad or ther is some peas the is back of the block if it is not in it will not let the oil gose up and i am going to see that after tow dayes and i dont see any sucking oil into the exhaust or white smoke.becuse i orady hade broken piston and i changed all my pistons and rods.
thanks for help.
thanks for help
Old Jul 2, 2005 | 08:06 PM
turbo-max's Avatar
thanks for help.
thanks for help
wow...where you located?
Old Jul 2, 2005 | 08:27 PM
Rick@Synergy's Avatar
15 psi and NOOOOO fuel system? Might as well buy another set of rods and pistons. Might as well get a new block too while your at it. Good luck.
Rick
Old Jul 2, 2005 | 08:52 PM
turbo-max's Avatar
Rick
LOL!!! did you have trouble reading his e-bonics crap too? or was it just me?
Old Jul 2, 2005 | 09:07 PM
Wolfee's Avatar
Either a migrant or he is over seas. I HOPE he isn't in this country though, that would make me feel better about the green card process
Wolfee
Old Jul 3, 2005 | 01:30 AM
Arkangel77's Avatar
sounds Like that motor needs some work for sure! Again - I guess?
Old Jul 3, 2005 | 05:09 AM
thanks all,
i am from over seas.but i can tolk good but i cant right that good iam sorry that i cant let you understand me.
thanks,
Old Jul 3, 2005 | 07:21 AM
turbo-max's Avatar
thanks all,
thanks,
that makes more sense now...good luck
Old Jul 3, 2005 | 10:32 AM
NOSjohn's Avatar
Restricted User
turbo-max and Wolfee: try to be a little more open-minded. At one time we were all immigrants and had a tough time adapting. Unless you are an American Indian, how about having some compassion, without the stereotyping, and help the guy out?
firehawk123: check your basics first - 1) take off your oil feed line and return line and make sure you have oil flowing through both. 2) if the turbo wheel is not spinning, while the car is running, then it's possible the turbo is bad or is not getting oil to provide the adequate lubrication for it to spin. In turn, your oil is being blocked at some point in the oil supply. 3) check all filters, lines, connections, etc for blockage.
Old Jul 3, 2005 | 02:17 PM
Arkangel77's Avatar
John C.
Well Said Bro! You make a good point and also gave some good Advice!
Old Jul 3, 2005 | 05:32 PM
thanks john for you help,and i will do that tomorrow.and thanks to you Arkangel77 .
Old Jul 3, 2005 | 07:24 PM
Arkangel77's Avatar
GOOD Luck Mang
Old Jul 3, 2005 | 10:09 PM
NOSjohn's Avatar
Restricted User
You're welcome, I'm just trying to help people where I can and when I ask a question, I get the same help in return.
