408 With F1
Old Jul 6, 2005 | 10:56 AM
koji777's Avatar
Default 408 With F1
I'm completeing my 408 build, FAST intake, 90mm tb, Long tubes, 96lb low impedance injectors (Acceleronics.com) , Cam choice by Comp, based on flow characteristics of my Patriot Stg 3 heads. etc.....
My goal is 800 RWHP.... Attainable???
What clutch should I go with.... SPEC STG 5???? Streetable???
Does anyone have a bin file (HP tuner) that would get me in the ball park, I don't want to dyno the car until I put 500 miles on her at least.
Any help deeply appreciated.
Old Jul 6, 2005 | 11:02 AM
bd2bonez06's Avatar
Yes it is obtainable, I have the same setup with an f1r and made over 800rwhp with 14lbs of boost and a mild tune. I can try and email you the hp file if you like
Old Jul 6, 2005 | 01:01 PM
koji777's Avatar
Default Tune
That would be great!! 1bad200ss@***.net
Is that an HP tuner bin file?
What did you do for fuel???? Did you go FMIC? Are you running Bosst referenced fuel PSI regulator? Any pics of your setup? Any help appriciated!!
Old Jul 6, 2005 | 02:26 PM
bd2bonez06's Avatar
Its a custom fuel system on a 03' z06 built by LWA of doraville,ga. I have a F1r custom kit with FMIC from A&A corvette. I will email the file when I get home tonight and yes its a HP tuner bin file Hey I see your from the Shreveport, La area. I am from Longview,Tx. Use to hang out in shreveport all the time when I was younger, went to college in La.
Old Jul 6, 2005 | 04:10 PM
koji777's Avatar
Default Kewl!
Awesome man!..... I just want to be able to crank the car before I take her to the dyno...about 500 miles of driving on her. I hope all works out for me... I've invested quite a bit and I want every safe ounce I can get out of her. You are running 14# boost... why not 20# etc..... I just want to know the safe max @ 9:1 cr ... don't wanna blow her up Thanks again
Old Jul 6, 2005 | 04:12 PM
koji777's Avatar
Default clutch
what kind of cluth are you running???
Old Jul 6, 2005 | 08:48 PM
bd2bonez06's Avatar
I am running a twin disc mccloud, I may up the boost later but right now i am happy with the power.. with more boost I would need either race gas or alky injection.
Old Jul 6, 2005 | 09:26 PM
99SS-T's Avatar
damn those twin dicks are sick. Sick expensive and sick grip. Should be up to your tasks about as good as any other. GL man
John
Old Jul 6, 2005 | 11:16 PM
bd2bonez06's Avatar
email sent
Old Jul 7, 2005 | 10:38 AM
koji777's Avatar
Default email
Havent received if you have sent... 1bad2000ss@***.net
Thanks again
Old Jul 7, 2005 | 02:50 PM
bd2bonez06's Avatar
[QUOTE=koji777]Havent received if you have sent... 1bad2000ss@***.net
You know what look at your earlier post it said 1bad200ss@***.net I was wondering about that. I will resend it when I get home tonight
Old Jul 7, 2005 | 03:10 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Who did your tune and what pulley sizes are you runing?
Keith
Old Jul 8, 2005 | 12:54 PM
koji777's Avatar
Default bin
Haven't received.... Don't give up on me!!!!
Lemme know when you try again and I'll keep an eye out...
Thanx again!!
Mark
