Just some info on testing with Nitromethane injection
Jose
I will agree with you on that-Sandman!
Sand for the nitro getting out of control I have thought about that already. I figure though with the low % we are running I'm still safe. Also we have a toggle switch to shut the pump off directly. I would like to tie the pump to a window switch of some sort though.
Jose
John
3. The hp #'s over using just meth alone are ~12% over, but the torque #'s jump up quite impressively. As much as 19%. Keep in mind..this is only a ~2% mix.
For 2., what where you before and after numbers?
Keith
Interesting test, but what about us little guys that can afford to shell out for someone to mix with a hydrometer and wouldn't really need the stuff unless it was for a money race
I think the "little guy" .....................
1.) should just use something like the snow nitro stuff that's already mixed.
2). just use some nitrous, even though about 50 percent oxygen from nitro has more power potential than the 30 - 33 percent (i think) oxygen of nitrous, I imagine nitrous is more forgiving.
3). Let these guys who can afford to break stuff finish their R&D, and also listen to those who know what they are doing and follow their advise closely and ..... and still be realistic and know something can break.
I might try it , when I get going, but I will be ready from broken parts, and also have a spare engine, pistons, and or transportation when or if I try.
And even still, I will probably just use a little, and try to stick to advise of those who have experience. From what I see , It can have great gains, but if you are not willing to accept the risk, wait for Jose and SAND etc or others that have REAL EXPERIENCE or use the Snow stuff or a shot of nitrous, and still , be ready, .... not neccesarrily expecting, ...... but ready if things go wrong. Hey I know it's good stuff, but not quite that good.
A small RC engine can get a big boost from that but not a big Blown V8.
So IMHO you are using a lot more than 2% nitro in the tank if in fact any gains are from the nitro.
I would rather see Volume as the measurement since everybody can easily relate to that.
I have not tried any nitro in my motor blown. I have tried it N.A. though using the Price chemical stuff at 1qt of 40% per 5 gals of gas. That works out to 2% of the total fuel by volume.
It did not do a whole lot, maybe more midrange and maybe a tenth in et. I did not add any timing though.
I'm not knocking these tests. I am quite interested myself. I have talked it about this many times with friends. Usually it just ends up being Nitrous is a lot easier to deal with and I forget about it. But I do have a gallon of 30% sitting here that keeps catching my eye.
Steve
oh no worries here mate, you don't see me jumping off the "gorge" bridge even with a parachute because it's "cool" or will give me more HP. I've learned from reading here pleanty that watch those with more experience and knowledge than I make the mistakes first to learn where the limits exist. John
John
