BOV recommendations?
Old Jul 7, 2005 | 06:24 PM
Mark C's Avatar
Default BOV recommendations?
Can anyone recomend a BOV, and a place to get it?
The quieter the better for me. My motto is "Why advertise?".
Engine is getting built right now. Should be 8.2:1 or so. I'll be maxing out the smaller Incon turbos, so I looking at about 600rw.
Old Jul 7, 2005 | 09:08 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
The Tial 50's are quiet and best for the money.
Jose
Old Jul 7, 2005 | 09:59 PM
2000 Tran Zam's Avatar
damnt, i am gettin a 50, i want something loud as hell.
Old Jul 7, 2005 | 10:04 PM
LS1TECH Sponsor
If you want loud, then look no further then the Turbosmart Megasonic. One of my local customers came by this past weekend and took me for a ride in his 383, GT45 powered Chevy II. The megasonic was AWESOME. Lets put it this way. I have dual Tial 50's on my personal car and am pulling them off. I have megasonics on the way....hehe .
Old Jul 7, 2005 | 10:14 PM
gator's 99TA's Avatar
i am sure futral can hook you up.
Old Jul 8, 2005 | 09:11 AM
sb427f-car's Avatar
SSU'S Vice Mod
As far as BOV design, function, and placement, what's the best route to go? I'm kinda with Mark C on this, the quieter the better. Does it make sense to route the dump back into the intake track for the turbo like a procharger setup, or no?
Old Jul 8, 2005 | 10:02 AM
libertine1015's Avatar
Jose, I have a question. Does the PTK kit Bov to atmosphere or does it return to the intake track?? and would it really matter for a automatic car? Right now my system has a return but what fun is that?
Old Jul 8, 2005 | 10:19 AM
stevieturbo's Avatar
If you want quiet. Get a BOV ( or more than one ) that re-circulates back into the intake. Depending on intake design there may still be some noise though ( ie an open K+N filter will still allow noise out, whereas a sealed airbox should be virtually silent. )
Old Jul 9, 2005 | 01:06 PM
Crazyplaya182's Avatar
Do you guys sell these or who does ?
Old Jul 9, 2005 | 01:14 PM
Brains's Avatar
Jose, want to dump one of those TiAL units cheap?
Old Jul 9, 2005 | 02:18 PM
LS1TECH Sponsor
Brains, I may just do that.
Crazy we carry every brand just about you can imagine...even some that you can't...lol
Old Jul 9, 2005 | 02:40 PM
Can you pm me a price please sir
Old Jul 9, 2005 | 08:28 PM
LS1TECH Sponsor
Sent
Old Jul 9, 2005 | 09:23 PM
Jeremiah's Avatar
My Tial 50 is loud as hell, flutters constantly under cruising and sounds like someone opened a blow off valve on an air compressor when I let off from a full throttle pass. If you can stand the constant fluttering when cruising then the Tial is a good peice. With the ATI supplied bypass valve on my car the compressor was being pressurized and leaking oil, the Tial fixed the problem.
Here is a picture of my set up...
Old Jul 10, 2005 | 02:51 AM
Boostaholic's Avatar
Jose
another vote for tial 50
Old Jul 10, 2005 | 02:12 PM
Originally Posted by Jeremiah
My Tial 50 is loud as hell, flutters constantly under cruising and sounds like someone opened a blow off valve on an <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=31&k=air%20compressor" onmouseover="window.status='air compressor'; return true;" onmouseout="window.status=''; return true;">air compressor</a> when I let off from a full throttle pass. If you can stand the constant fluttering when cruising then the Tial is a good peice. With the ATI supplied bypass valve on my car the compressor was being pressurized and leaking oil, the Tial fixed the problem.
i dont think ill have a fluttering sound as i am having it put in with a turbo.
do you have any sound clips of it? im curious as to what it will sound like.
Old Jul 10, 2005 | 03:22 PM
Jeremiah's Avatar
I dont but I have seen some on this site before, you might try a search.
Old Jul 11, 2005 | 11:21 AM
sb427f-car's Avatar
SSU'S Vice Mod
With a turbo setup, is there any advantage to ricirculating it, or is it better to just dump it to the atm.
Old Jul 11, 2005 | 01:21 PM
Brains's Avatar
Really doesn't matter, as long as whatever engine management system you're running isn't adversely affected. If you run a MAF, you'll want to put the BOV prior to the MAF. Otherwise the only real difference is noise.
Old Jul 11, 2005 | 02:08 PM
sb427f-car's Avatar
SSU'S Vice Mod
Gotcha. So, with a bypass vs a blowoff, with making boost quicker between shifts with a 6spd car on a turbo make that much of a differnce? I know the bypass doesn't really evac all the air in the system and a bov recirced wouldn't really do the same (on a stock style blow through MAF that is). I'm just trying to learn the ins and outs of the two, I still don't really get it.
